Hi Guys,
The purpose of this post is....
After you have unlocked your Rigol MSO5000 You may want to learn how to use every feature of the scope.
I have received a lot of requests to help people
- Unlock their scope
- Help when unlocking goes wrong
- How to use the scope because they are beginners and are not sure how to use their scopes
This Post hopes to achieve 3 GoalsGoal 1 - To Explain to you how to upgrade the scope and confirm that you've actually done it correctly
Goal 2 - To show you what to do after you upgrade the scope and how to set things up
Goal 3 - To walk you through your scope (Every Feature) and teach you how to really take advantage of your scope.
(This will mainly benefit the beginner)FIRST OF ALL, CREDIT WHERE IT'S DUEHere is the original Posthttps://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/Here is a post i created later that was shorterhttps://www.eevblog.com/forum/testgear/solutions-and-troubleshooting-hacking-the-rigol-mso5000-series-oscilloscopes/Moving forward
1. I have created a few videos for you guys so i don't need to keep explaining things over and over.
2. The videos are also there for the beginners because you're not going to absorb everything straight away, so, Keep them as reference, Learn from the knowledge and expand upon it and explore for yourselves
HERE IS A LINK TO THE CLOUD (it's safe and virus free)https://mega.nz/folder/OsJyFY5A#8uS0fmepgBdNrXqvnxmFfg(Save this link so you can get the future video uploads)
There are several things on this cloud
- The Rigol MSO5000 User Manual (RTFM) You should read it
- All the Upgrade files "Upgrading to 350MHz"
NOTE : This set of files takes you from Version FW:01_03_00_03 to FW:01_03_03_00
YOUR SCOPE MUST START ON FW:01_03_00_03 for this to work, if it is on a lower version, Message me and i'll give you another .GEL File.UPDATE : the above method is the
"Patching Method",
The Patched method DOES NOT survivefirmware upgardes, The better way to do it is to use the Dr Mefist0
LICENSING METHOD using the python script. This method
will survive all future upgrades which means you never need to patch your scope again and you'll be free to just download legitimate
Rigol update files from the website and install them.
The link to the detailed information on how to perform the Licensing Method is here
https://mega.nz/folder/OsJyFY5A#8uS0fmepgBdNrXqvnxmFfgNow even though the purpose of this post is not primarily to help you upgrade, i have included the files for convenience because everyone keeps asking "where are the files" so here they ALL are in one place, Just download the file, Unzip it
and follow the instructions in each folder
Then i have 2 spreadsheets there so far.
- Capacitor Inventory and Test List
(For Accurately Testing E.S.R. on a capacitor) This is covered in the videos
- Inductance Value Calculator
(For establishing the value of an unknown inductor. This is a spreadsheet that Automates the math)
You're going to need to build a tank circuit to test the inductor
The formulae in this spreadsheet are password protected so you don't accidentally erase them
the password for the spreadsheet is abc123 (go to REVIEW then UNPROTECT SHEET)
This is just for reference
NOW THE VIDEOSCAUTION : This is not a quick video list, These video's take several hours to go through, As a result i have broken them up into subjects. I don't want to hear TLDR. You either want to learn how use your scope or you're happy to always stay on a basic level in which case this was not the scope for you, you should have paid $100 for a USB Cheapy scope.
THESE VIDEOS ARE TO BENEFIT THOSE PEOPLE THAT WANT TO LEARN EVERYTHING ABOUT THEIR SCOPE AND TAKE FULL ADVANTAGE OF WHAT THEY HAVE PAID FOR. Expect to watch at least 5 Hours.
That aside, the videos are...
1. Intro - 17:57 54.7MB
(as the name states, it's an introduction , overview video)
2.Firmware Upgrade - 1hr: 3:05 182.4 MB
(In this video, before getting into the fun stuff i confirm that you've done everything problem. i run through the Firmware upgrade process and patching process, If you are having problems upgrading then this is the video you want to watch),
Use the Upgrade zip file with this video as a step by step walk through.
3. The Basics of DSO 1hr:19:28 311.0 MB
(In this video we start walking through the basics of using your scope by only covering basic concepts)
NOTE : For experienced users there will be features here that you are not aware of, so it's worth watching.
4. All the Settings 1hr 52:57 410.1 MB
(In this video we go through all the settings in MSO5000, A Step by Step walk through of everything)
5. ESR Spreadsheet 14:37 46.8 MB
(in this video i explain how to use the ESR Spreadsheet when testing capacitors)
6. Inductance Spreadsheet 5:54 18.4 MB
(In this video i explain how to use the spreadsheet to calculate the inductance of an unknown inductor)
7. Using Your Waveform Generator 1hr 17:57 - 262.5 MB
(This video goes into depth on how to use your Waveform Generator as well as practical examples of how to test components
while doing so )
8. Using a Crap AWG 15:27 90.4MB
(A Quick video to show the negative affects and reality of buying a cheap Signal Generator vs a better one
and spending more on it. Essentially proving it's not worth buying a cheap one if it doesn't give you what was promised)
9 How to Use Cursors on a Scope 2hrs 00:33 451.6 MB
(In this video i go into depth on how to user Cursors on an Oscilloscope and give several practical examples of where
they are useful )
10. Math and FFT 39:53 185.4 MB
(In this video i explain Math Functions on the scope and go into depth with F.F.T. )
THAT'S IT, THOSE 10 VIDEOS , I FEEL SHOULD BE ENOUGH TO GET ANYONE UP AND RUNNING WITH THEIR SCOPE
UPDATE - 2 Additional Videos have been added
11. MSO5000 vs DS2000A 14:23 97.5MB
(in this video i look at how a recent number of updates to the DS2000A has caused it to perform better vs the MSO5000)
12 . HELP Menu 197.5 1hr 11:21
(in this video we explore the internal Help Menu in full)
13. MSO REFERENCE Menu
(In this video we look at creating Reference Wave forms for analysis)
Any Questions, Let me know
BE COOL
