Author Topic: Portable Oscilloscopes List (cheap)  (Read 15993 times)
Offline awakephd
Re: Portable Oscilloscopes List (cheap)
« Reply #75 on: September 23, 2024, 09:07:53 pm »
I recently got a Zeewei DSO3D12 to replace a DSO154 - main reason for replacing the latter was that I accidentally cracked its screen. :(
If you are familiar with the DSO154, the DSO3D12 will feel very similar in terms of UI - even though it has quite a few more buttons to control its operation. The latter is a good thing, I'd say, increasing the convenience of changing time base or vertical scale in particular. The one thing that was mildly annoying in the UI is how to move up and down in the menu - annoying only because I could find absolutely nothing in the manual to tell how to do it. I had to try various buttons until I finally realized that it treats the column of buttons next to the display as "soft buttons" to select each menu section. Within the menu section, the arrow buttons and OK button work as expected / much like the DSO154.
Is it worth the extra $50? Well ... jury is still out on that. I mostly just wanted something portable and battery powered for times when those attributes are needed. Dual channels is definitely a plus for the uses I have in mind for it. An actual case feels like it might be less likely to succumb to damage than the DSO154 proved to be. All in all, I have no buyer's remorse; it's just hard to get as excited about this for $80 when I had something that felt and looked very similar for $30 - albeit only 1 channel, smaller screen, and lower specs.
Offline Fungus
« Reply #76 on: September 23, 2024, 09:23:39 pm »
Just watching the Zeeweii videos in this post:
https://www.eevblog.com/forum/testgear/another-dsodmm-zeeweii-dso3d12-claimed-120mhz250msps/msg5274556/#msg5274556
Imagine you're starting out from zero...  it gets you a lot of capability for $100 bucks (multimeter+scope+siggen).
I like the display of where to put the multimeter cables:
« Last Edit: September 23, 2024, 09:25:51 pm by Fungus »
Offline Fungus
« Reply #77 on: September 23, 2024, 09:33:38 pm »
Yep, menu looks almost identical, but much easier to navigate.
Setting timebase and vertical is much easier, too - dedicated buttons!
Single channel is a big limitation.
This one has multimeter, too. If I could leave the meter out of my case then it could be a win in terms of space. I'll have to make a cardboard model and see the real size.  :)
I'm tempted.
I'll sleep on it for a few days though...  ;D
Offline awakephd
« Reply #78 on: September 24, 2024, 06:10:20 pm »
Yes, that is one of the best features / most intuitive parts of the design.
Agreed, they did this very well. Even better would be a single set of inputs that are internally switched, but let's not get greedy ... :)
Offline BillyO
« Reply #79 on: September 24, 2024, 08:25:56 pm »
Bad idea.  Accidently making a poor a mode choice while connected to a strong voltage source or a sensitive circuit could cause myriad problems.  They don't keep inputs separate to reduce cost or make things easier for themselves, they do it for (what should be) obvious safety reasons.  You may have too much experience with cheap "Smart" meters that do not have current ranges.
The following users thanked this post: RAPo
Offline awakephd
« Reply #80 on: September 25, 2024, 02:42:39 pm »
BillyO, you are giving me far too much credit. In my case, it is a matter of far too little experience in general. Thanks for helping me to see the advantage of the separate inputs!
Offline Fungus
« Reply #81 on: September 25, 2024, 02:53:00 pm »
Current inputs are low resistance (passthrough) and have fuses*, that's why they make them separate.
You could do it with shared jacks but you'd need to add internal relays and all sorts of stuff and any bad range selection would blow your fuses.
(*) Yeah, I know the 10A range on this particular meter is "unfused".
Offline BillyO
« Reply #82 on: September 25, 2024, 03:01:03 pm »
I like to give people the benefit of the doubt.  :-+ :-+
The following users thanked this post: awakephd
Offline BillyO
« Reply #83 on: September 25, 2024, 03:12:14 pm »
Except in the case where your meter was hooked up to a small 50ma diode, or tiny transistor or.. something else that would not blow a 600ma fuse before giving it's own life to make yours is more interesting.
Also, even if the meter was smart enough to put a 10A fuse in line (not hard to do with a big, brawny relay) when in that mode, it better well be a darn good fuse if it suddenly finds itself across the 415v mains feed in a breaker panel in the UK.  Or some other suitably contrived situation (which do occur occasionally).
