I bought a pair of Pomona 8 pin SOIC test clips(part no. 5250) sometime ago and finally got around to play with them yesterday. Only after about a dozen clips, one of the leaf contacts felt like it caught on a pin and ripped out.
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
The contact was permanently bent upwards and there was no way to bend it back. After taking the clip apart, I didn't have any confidence in the method that was used to secure down the leafs. It looked weakly melted into position.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
To remedy the problem, I put a blob of epoxy over that area. For the bent leaf, I held it down with a tip of a small screw driver while it cured.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I had a look this morning and it appears that I messed up one side. The epoxy flowed too far forward which inhibited the movement for a couple of the leafs. The clip no longer sits flush to the board and rides up one side of the chip. Oh well.
