Yeah, test leads not the most exciting topic in the world but I still felt these were worth reviewing. Walking through Fry's today wasting time and I came across these test leads. I don't really NEED test leads I knew Pomona tends to be high quality. At $13.99 for leads from a quality company I decided to splurge and take the gable.
![](http://i.imgur.com/pfoBRGC.jpg?1)
At this price you aren't getting much more than the leads but thats all I was interested in. The package contains a red and black test lead with matching caps for the probe tips. They are rated as Cat II 1000V without cap. Cat III 1000V/Cat IV 600V with the tip caps. The tips are super sharp and the caps fit snugly without being annoying.
![](http://i.imgur.com/80qJQns.jpg?2)
![](http://i.imgur.com/KtcJWWK.jpg?1)
If I had these caps much less likely I kill the zener in my 199. The 18AWG wires are wear-indicating double-layered safety silicone (finally! I have leads that aren't plastic/rubber coated) while the tips and handles are polypropylene with a soft elastomer coating which feels VERY nice in the hands. It reminds me of the soft-touch coating on some smartphones. The leads read 0.06ohms impedence when shorted on my UT61E. Speaking of, continuity testing using these tips is virtually instant with no signs of a coating. It really reinforces how nice the UT61Es continuity buzzer is.
![](http://i.imgur.com/3DFR94T.jpg?1)
![](http://i.imgur.com/N7GcRep.jpg?2)
Also, I should point out the banana plugs are real banana plugs not the typical split metal prongs like on cheaper probes. I know this pic doesn't show it very well but its the best I could do.
![](http://i.imgur.com/WGOqfDc.jpg?1)
Summary:
First and foremost, I can say these leads are by far the nicest I have owned but they are also the first quality leads I have owned. So I have nothing to compare it to. The cable is double-layered safety silicone which doesn't tangle. One thing I should mention is how LONG they are. At 120cm (4 ft long for us yanks) the length is actually significantly longer than any of my other leads. I could see when using these on a test bench that length is welcome but I think in other situations it is a tad of a drawback. I actually like the caps as they are not cumbersome or annoying; simple to remove and simple to put on. Need I mentioned again that I got all of this for under $15 after taxes and I must say that I am QUITE happy.
