We use a Linx inkjet printer at work with the same red light. Flashes when it is stopped, or when you are doing an edit of the print, or when it has low solvent, ink or a fault. I never buy the ink for it, the solvent use is around 40 bottles per year though, the ink tank holding 1.5l of ink being enough to run it easily between services, when the tank is cleaned to get to the pickup and coarse filter in it. All internal piping for ink and the MEK solvent is PTFE, along with all the fittings and wetted parts of the valves and pump.
