I have another category for you:
Aneng AN8009 has auto power off after 15 minutes even if you are actively using it.
There is also a beep warning at 14 minutes that it will power off in the next minute.
If you hold down the yellow select button when powering on the auto power off is disabled.
However the meter still beeps at you after 14 minutes and then 15 minutes.
Or put more succinctly:
Switch on:00:00 beep!
14:15 beep beep beep beep beep!
15:15 beep beep beep beep beep!
(then powers off).Switch on with SEL held down:00:00 beep beep beep beep beep!
(does not power off).29:30 beep beep beep beep beep!
30:30 beep beep beep beep beep!
(repeats indefinitely).
