Author Topic: Pocket-Sized 6 GHz 1 TS/s ET Scope  (Read 322843 times)
0 Members and 11 Guests are viewing this topic.
Online joeqsmith
Re: Pocket-Sized 6 GHz 1 TS/s ET Scope
« Reply #350 on: February 18, 2024, 04:57:04 am »
Note that we are nominally out of office this weekend. But this was a small enough change, and is holding up the review.
I work full time, plus double downing on your product.   That's my level of commitment!   :-DD  Sleep, what's that!  :-DD
Using the demo mode and comparing the previous version,  there is a slight improvement in the contrast.  It seems you feel this is one of the main selling points.  Before I spend time changing my review,  I want to make sure that you are satisfied with your software.  I can certainly postpone the review if you feel you can improve it.
A bit of advice, because I assume you actually want to leverage these reviews for sales, in my experience, if I make a multi-part series,  the first and last videos will see the highest view counts.  If we make a follow up video showing software improvements, I doubt it will have half the views.  IMO, you really only get one chance at it.   For me, this isn't really a problem.  It's a small channel and isn't there to make money.  IMO, it is something you should consider.   Give it some thought and let me know.
Online joeqsmith
« Reply #351 on: February 18, 2024, 01:51:05 pm »
Enable color grading, then disable the channel, waveform is still displayed.   Disable still works when color grading is turned off.
Saving the defaults does not store the state of the color grading when it is selected.
It seems that it limits the maximum data points to 3072.   It's a PC with basically unlimited resources.   Why is there such a limit?
Currently this is due to the way some algorithms (e.g. histograms) and display (e.g. OpenGL buffer size) are implemented. This limit can be drastically improved (to the ~million scale); it's just a matter of priority, and putting the work in. We can have it in by next update if you find it important.
My only goal was to improve the contrast of the eye by adding more data (further slowing down the collection).  It is more if you find it important.  It may not help.
Offline SJL-InstrumentsTopic starter
    • SJL Instruments
« Reply #352 on: February 18, 2024, 05:00:20 pm »
The demo mode uses a simulated (idealized) eye diagram, and the contrast is already good with default settings. You will likely see a larger contrast improvement when using the actual hardware.
Fair points. Perhaps the single largest area of improvement is the sweep speed (as you mentioned in the review). As we estimated in our reply #282, it is theoretically possible to make the sweep 10-100x faster with careful firmware optimization.
We suspect this will take 2-4 weeks to get right and thoroughly test, but it will make a qualitative change in the viewer's first impression. It may be worth waiting until this improvement to post the review.
As a middle ground, perhaps you could link the (unlisted) current version of the review here. This will let the community members here voice their thoughts, and suggest anything they'd like to add. We also suspect that those who are following the thread closely enough to see the link will also watch an updated version when it becomes public.
SJL Instruments | San Jose, CA, USA
Pocket-Sized 6 GHz 1 TS/s ET Sampling Oscilloscopes
https://sjl-instruments.com
    • SJL Instruments
« Reply #353 on: February 18, 2024, 05:27:13 pm »
Both fixed in below prerelease:
https://gigawave-releases.s3.us-east-2.amazonaws.com/GigaWave_v2.5.10_PREVIEW_2022-02-18_Windows.zip
Note that this feature will go through our normal QA process later this week, before the public v2.5.10 release.
For this purpose, increasing this limit will likely not help. 3072 points is already finer than the pixel resolution of the display.
Online joeqsmith
« Reply #354 on: February 18, 2024, 09:32:24 pm »
I have updated the review to include the new software with the color grading feature.
The following users thanked this post: Kean
    • SJL Instruments
« Reply #355 on: February 19, 2024, 12:46:40 am »
Just saw you posted the review - thanks for the last-minute change. We're quite happy with how it turned out, and grateful for your patience and constructive suggestions over the past month.   :-+
Do you mind if we link to/embed your video on our website?
Going forward, feel free to continue posting any suggestions or feedback here. (This of course includes any new viewers coming from the video.) Next software update is scheduled for this coming weekend.
Online joeqsmith
« Reply #356 on: February 19, 2024, 01:10:48 am »
It was my pleasure.  Its always such a treat to work with people like yourself who are interested in improving their products.
Not at all.  I also suggest you link it to your very first post in this thread to make is easier to find as the thread grows.
Online joeqsmith
« Reply #357 on: February 24, 2024, 05:32:05 pm »
They have released new software which includes an auto setup.   It's a big improvement over what I showed during my review of the 6400.   Some of it is still a bit crude.  For example, they allow you yo change the color for the min/max but entering in (guessing a 32-bit) hex number.  By a show of hands, how many of you have that memorized?   Most software is going to present the user with a color wheel, with a simple point click.
I would like to see a single button select for basic horizontal or vertical measurements with trending.   Maybe more useful than a way to sweep faster.
When vectors are disabled, what prevents you from calculating Tr?  Don't you have all the data needed for this measurement?
Version 2.5.10 (2024-02-23):
- Automatic setup for vertical offset/scale and trigger level.
- Color-grading for multivalued signals
- Allow double-click when selecting device on startup
- Always show reset button when vertical scale is "Custom"
- Allow smaller vertical scales (1 mV/div)
- Keep settings from last closed FFT window when opening new one
- Include FFT configuration when saving settings
- Bugfix: Dialog boxes briefly flash on startup
    • SJL Instruments
« Reply #358 on: February 24, 2024, 05:48:21 pm »
Our plan was to release v2.5.11 tomorrow (Sunday) and post a notification here. This version includes a GUI color picker (among other features). Other features are currently going through QA.
The v2.5.10 minor update was needed for another reviewer this weekend (in particular the color-grading feature).
To clarify, do you mean a button which adds several basic measurements at once for a specified channel?
By trending, do you mean min/max/avg measurements?
Yes, but only if the signal is single-valued at each point in time. In an eye diagram with double-edging, for example, it's ambiguous which feature Tr should be calculated for.
In the case where the signal is single-valued, the software would extract the average and then calculate Tr. This is equivalent to having vector trace mode on. For clarity, we chose to require vector mode to be enabled (as to not produce garbage with multivalued signals).
For next update (~March 9), we'll see if it's possible to reliably detect when the signal is single-valued. Then all measurements would be available with vector mode disabled, but would give an error if they cannot be accurately calculated.
« Last Edit: February 24, 2024, 06:09:37 pm by SJL-Instruments »
Online joeqsmith
« Reply #359 on: February 24, 2024, 06:10:19 pm »
For example basic horizontal would be frequency, period, rise/fall, width, duty cycle ...  Trends would be min,max, p-p, avg, std-dev...   (histograms would also be nice) See attached for example.   Adding basic measurements is a pain.  Having the ability to save the settings has been very useful but not a work around.
I'm surprised the software can't back it out or just have two processing paths.  I get what you are saying about avoid showing garbage but it seems odd that it can't make basic measurements in all modes.
It may be a good tradeoff.
« Last Edit: February 24, 2024, 06:17:30 pm by joeqsmith »
Online joeqsmith
« Reply #360 on: February 25, 2024, 04:32:54 pm »
From the manual:
When vector trace mode is disabled, the full distribution of the measured signal is displayed with
intensity grading.
While you have described how to calculate the voltage for a given time, you do not explain how this full distribution is derived.   Can you provide more details?  Are you still working with the same set of data from the R command?  If so, do you still toss out the same outliers?
... if the signal is single-valued at each point in time.
I assume that this full distribution is needed to see the multiple points in time.
When vector trace mode is enabled, the channel is drawn with one continuous line that follows
the average of the measured sample distribution. The standard deviation will be shown as a band
around the trace, indicating of the noise level.
I assume this standard deviation is also looking at the same full distribution.
    • SJL Instruments
« Reply #361 on: February 25, 2024, 05:06:28 pm »
From the manual:
intensity grading.
The full probability density function (PDF) is obtained by numerically differentiating the CDF data from the R command. You can implement this with a finite difference. Nothing is tossed out.
Yes, the full distribution is required for multivalued signals such as eye diagrams.
The standard deviation can be calculated from the PDF. The software calculates it directly from the CDF for numerical efficiency (integration by parts), but it gives equivalent results.
« Last Edit: February 25, 2024, 05:11:47 pm by SJL-Instruments »
Online joeqsmith
« Reply #362 on: February 25, 2024, 05:26:10 pm »
... we'll see if it's possible to reliably detect when the signal is single-valued.
Based on your last response, your previous post makes more sense.  So, you assume if the vectors are turned off that the user is looking at multi-value points and hence, turn off the math calculations.  It's not that you can't calculate them assuming it is single value points, you just don't, at least for now.
Much more clear to me now.  Thanks.
    • SJL Instruments
« Reply #363 on: February 25, 2024, 08:52:59 pm »
We have just released v2.5.11 of the software which contains these features. Histograms are scheduled for next update, but for now the measurement history can be exported as a CSV.
Changelog (https://www.sjl-instruments.com/software/):
- Allow measurements to be edited
- Track measurement statistics (min/max/avg/pp/stdev/etc.)
- Export measurement data
- Add pulse width measurements
- Quick add all standard horizontal/vertical measurements for a channel
- Quick remove all measurements for a channel
- Automatic reconnect if scope is unplugged
- Color picker for min/max
- Bugfix: Brightness slider does not respond smoothly at low update rate
- Bugfix: Attenuation does not update when acquisition stopped
- Bugfix: Measurements loaded improperly from settings file when measurements exist
Online joeqsmith
« Reply #364 on: February 25, 2024, 11:51:19 pm »
Looks like the actual changelog was not updated.
Nice job with the new release.
    • SJL Instruments
« Reply #365 on: February 25, 2024, 11:53:02 pm »
It may be cached by your browser. Try a refresh - this goes for the manual as well.
The following users thanked this post: joeqsmith
Online joeqsmith
« Reply #366 on: February 26, 2024, 02:02:21 pm »
Ran the new software a fair amount and did not find any problems.   Looks like you fixed some of the minor problems I saw with the previous versions.   I like you are taking the time to clean it up as well as adding features.   I like the new dialog readout.   The auto setup has been working well for me.  A time saver.  I like that I can tune the time base to get it close and have it auto adjust from there.  It was a good idea.
IMO, the two big ticket items now are programming the FPGA and microcontroller over the USB, if it is even possible.  The other is or course, can it be sped up with a loss of performance.   I make use of the manual resolution settings to hunt down the timing but that only helps so much.  Having a way to sweep faster would be very helpful even suing the setup phase.
While making the review, I though about comparing it with my old LeCroy 7200 while looking at an ignition signal.  The problem is that I am working with trigger rates <500Hz.  The scope is currently just too slow for this application.   It may be a case where it just isn't going to be a good fit for this application.
    • SJL Instruments
« Reply #367 on: February 26, 2024, 02:53:44 pm »
Thanks for the feedback. Glad to hear that the recent features have been helpful, and that no new bugs have cropped up.
USB-based DFU for the FPGA and microcontroller is possible with the current hardware. It just takes time to implement. Our plan is for the next firmware revision (v14) to be the last one requiring external flashing hardware.
So far we have sped up the firmware by a factor of ~3 compared to v13. Above 500 ktrig/s, we can achieve at least 30x practical speedup based on our accounting of timings. This also just takes time.
Before release, will also need to rerun our glitch/performance/temperature tests for at least a week, as these are substantial firmware changes. It's a bit early to give an ETA, but we're aiming for end of March.
The theoretical minimum acquisition time for one point @ 500 Hz trigger rate is 12*2 ms = 24 ms for 12-bit resolution, with 1 trigger per CDF sample. At 4 pts/div, this is ~1 second per sweep. Slow, but usable.
For comparison, we measure ~250 ms required with firmware v13 @ Nmin=5, Nmax=5, K=12 with 500 Hz trigger. We measure ~15 seconds/sweep with these settings @ 500 Hz.
So practically, there's a factor of 10 to be gained at low trigger rates.
Asymptotically, CDF sampling requires about the same number of triggers as an ADC sampler, when the full distribution (noise, eye diagram) is required. (Section 2.1.2, point 3.) This holds in the limit of many points acquired. But for single-valued signals where only 1 sample is needed, CDF sampling requires 12x more triggers for a 12-bit resolution.
Online joeqsmith
« Reply #368 on: February 26, 2024, 04:35:00 pm »
From the manual:
intensity grading.
While it seems simple enough, based on my past history, let's start out making sure I am interpreting your comments correctly.  Shown is the PDF for your example data from 4.3.3.   Assuming this is correct, you just directly plot this data when the vector is disabled?
    • SJL Instruments
« Reply #369 on: February 26, 2024, 06:26:40 pm »
You should also take the differences of the voltage array, and perform a division. The PDF is given by dF/dV.
Online joeqsmith
« Reply #370 on: February 26, 2024, 08:19:34 pm »
Shown with diff and division for example.  Numbers seem very high.  When you plot this, do these values go through another conversion?
    • SJL Instruments
« Reply #371 on: February 26, 2024, 10:28:16 pm »
Yep, these numbers look correct. Units are in probability density per volt. For intensity-grading, the overall scaling is arbitrary and is controlled by the brightness slider. The official software has some auto-ranging for convenience, but it’s not necessary.
The first point in your result (with a negative dV) should be thrown out. Each final PDF value corresponds to the interval between two neighbouring CDF points.
« Last Edit: February 26, 2024, 10:40:31 pm by SJL-Instruments »
Online joeqsmith
« Reply #372 on: February 27, 2024, 12:20:24 am »
Thanks for double checking my work.    It's interesting how this thing works.   I will need to think about how best to plot it.
Poor mans PAM4 simulation gets a bit messy.   You can turn down the brightness to remove some of the dots, but the switch points will wash out.   Of course the question is if my test signal actually has this much noise.
    • SJL Instruments
« Reply #373 on: February 27, 2024, 12:23:21 am »
This results from statistical noise in the CDF samples. What value for Nmin (minimum triggers per CDF sample) are you using? The noise will reduce as you increase this value.
Online joeqsmith
« Reply #374 on: February 27, 2024, 12:40:19 am »
Auto.  So, I'm not sure.  Assuming the the grayed out values are what it is using, then 329.   If I manually bump it to 10,000 it does clean things up but of course, takes much longer to sweep.
