I'm at a loss of what to suggest. Same cables, generator, scope, splitter, PC, USB port, software... Scope and splitter resting on a ground plane next to my VNA. The setup wasn't taken apart between tests. I wasn't playing with my spark gap transmitter, ignition systems or anything else I would expect would cause a disturbance.
The only thing that has really changed is or course, its a different day and the office temperature was lower. As you know, I had tried to look at the stability with temperature but at that time we did not have the new FPGA/firmware. I plan to repeat these tests once your software has evolved. Maybe that has something to do with it.
Let me know if you have any ideas.
If the setup is not clear, see attached sketch.
