Author Topic: Pocket Multimeter Shootout  (Read 46055 times)
Online EEVblogTopic starter
Re: Pocket Multimeter Shootout
« Reply #75 on: August 11, 2017, 06:05:56 am »
Realised I forgot Amprobe DM78C  :palm:
I think it's an important contender.
RS have one, but $139+GST  :o
The following users thanked this post: tooki, kalel
Offline kalel
« Reply #76 on: August 11, 2017, 06:22:55 am »
Nice collection. Digitech design is kind of MP3/MP4 player styled?
« Reply #77 on: August 11, 2017, 06:39:14 am »
Pretty sure I won't include the Digitech QM1328 as it uses standard leads and has no case. If I include that then I guess I have to include the AN8008 and Fluke 101 etc
Offline kalel
« Reply #78 on: August 11, 2017, 07:03:49 am »
I meant the yellow one, not sure about the number. Looks a bit like an MP3/MP4 player.
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #79 on: August 11, 2017, 09:14:31 am »
@ Dave , Ask Charles at TRIO test if he has one of these in stock.
Extech DM220.  Might not be a true wallet style but should be easy to get hold of and add to the follow up testing.
Seems same thing as PeakTech 1020 A
http://www.peaktech.de/productdetail/kategorie/digital---handmultimeter/produkt/p-1020.html
Not strictly shirt pocket format, but been very reliable little puppy. Drag it around for years now - zero problems. That huge mains indicator lights up from very far away and can save the day, or maybe even life.
Seems that version currently on sale has replaceable probes now (inline connectors on cable, not by sockets on DMM).
« Last Edit: August 11, 2017, 09:17:09 am by MrW0lf »
Online ebastler
« Reply #80 on: August 11, 2017, 10:11:34 am »
I was going to ask about that one when I saw the photo.
I thought removable leads were verboten;)
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #81 on: August 11, 2017, 10:14:58 am »
Then the Aneng would need to go too.
But Id give that one a pass, because its all in one case.
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
Offline hans_ober
  • Country: in
« Reply #82 on: August 11, 2017, 01:16:28 pm »
You need to do a $50 and $100 shootout too. Been some time since you looked at that range.
« Reply #83 on: August 11, 2017, 01:46:22 pm »
[/quote]
Correct.
The Digitech one uses standard 4mm plugs and large full size probes, so I therefore deem it not to be a proper "pocket" meter, it's a "compact" meter.
« Reply #84 on: August 11, 2017, 01:49:23 pm »
Will start shooting this tomorrow.
The Amprobe is on order and I can include that at the last minute as it will likely take a couple of days to shoot this and compile the info.
The following users thanked this post: kalel
Offline idpromnut
« Reply #85 on: August 11, 2017, 02:50:40 pm »
@EEVBlog: I am expecting some cheesy packet multimeter quick-draw intro to this video!  Complete with pocket-protectors and dramatic close-ups! ;)
Offline kalel
« Reply #86 on: August 11, 2017, 03:26:36 pm »
Looking forward to the video already.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #87 on: August 11, 2017, 05:04:50 pm »
I have one: nice tool, but:
a)  the display cannot be easily read from below (when the meter is horizontal on the bench) because the display is too recessed from front panel
b)  at switch-on it defaults to AC volts, a little annoying for me
It's  a nice instrument, the Non Contat voltage tester  works very well. It has no case, so you must use a rubberband to keep the cables from creating a mess in the toolbox.
I could never find a way to open it without breaking the case.. any suggeston?
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #88 on: August 11, 2017, 07:05:16 pm »
No suggestion about opening, but heres one about using on bench:
https://www.thingiverse.com/thing:2121969
Think AC is safety measure. I use it mostly to solve "general household problems" that deal mostly with AC. Or stuff in dirty environment - construction site, checking fishing boat battery etc. Not IP rated but clearly built with harsh use in mind. If not see it in this contest, then maybe in next - "compact DMMs in enterntainingly dirty conditions" :P Perhaps one can first open zombies heads with U1282A and then poke around with rugged compact :popcorn:
« Last Edit: August 11, 2017, 07:18:46 pm by MrW0lf »
« Reply #89 on: August 14, 2017, 04:22:19 am »
OPINION NEEDED:
I just got this Sanwa PM300 pocket meter:
http://www.sanwa-meter.co.jp/prg_data/goods/img/PH61491811587.pdf
But I was looking at potentially reselling this one (initially without EEVblog branding), and have a quote and permission to resell it.
Now, that potentially puts me into a vested interest position if I include this in the shootout.
What do people think, will people trust my openness in a shootout in which I sell one of the meters? (of course I'll be upfront about it)
Although I haven't tested it yet, it might well win the shootout in terms of "cost is no object" metric. The range switch is to die for, CAT IV rated, solid case, gorgeous TPU case (but very thick), gold probes, good strain relief, and it kills all the others in build quality and look and feel.
But it is by far the most expensive meter, I'd have to retail for probably US$75. So it wouldn't win any bang-per-buck metric.
Opinions please...
Offline Lightages
  • Canadian po
« Reply #90 on: August 14, 2017, 04:30:01 am »
I say that you should include it. Nobody is immune to bias but if you state it then people can take your opinion with a grain of salt. You might also want to state that the Amprobe PM51A is made by Brymen and because you sell the BM235 that your opinion might be biased with it too.
I believe you are an honest person and would not lie to people to make a buck. That does not mean you could lie to yourself and therefore pass that lie on to others. Just be open and stop worrying about the people who might be suspicious of anything you say.
Offline plazma
    • Homepage
« Reply #91 on: August 14, 2017, 04:34:58 am »
OPINION NEEDED:
True RMS and 6000 count. I wonder what the chipset is.
Offline noidea
« Reply #92 on: August 14, 2017, 04:35:33 am »
Regards the Sanwa PM300 yes please go for it.
I noticed Kyoritsu / KEW have now have an update to the 1018, the 1019R which is True RMS but lacks diode test so is a non starter for me, the PM300 has it which looks promising.
http://www.kew-ltd.co.jp/en/products/detail/00023/
Is there any chance you can get hold of one of the KEW mini clamp pocket meters to throw in the mix?
http://www.kew-ltd.co.jp/en/products/detail/00923/
Offline amspire
« Reply #93 on: August 14, 2017, 05:00:01 am »
Definitely include the Sanwa. There is no problem reporting the facts. Subjective views, such as "I just love this meter" are fine as long as we know you have an interest in the meter. Anyway, it is your site - nothing wrong with promoting items that help pay for the site.
If you over-promote the Sanwa meter, you know you will spark off a deluge of a few hundred posts arguing the matter. Hard to be more open then that.
« Reply #94 on: August 14, 2017, 08:01:11 am »
That happens if I cough the wrong way  ;D
The following users thanked this post: casinada
Offline kalel
« Reply #95 on: August 14, 2017, 10:34:33 am »
OPINION NEEDED:
Opinions please...
I think you should include it with that acknowledgment. It might also explain why you want to resell the meter itself.
Online Fungus
« Reply #96 on: August 14, 2017, 10:36:25 am »
Nothing wrong with having categories of winners:
Under $20
Over $50
etc.
Offline kalel
« Reply #97 on: August 14, 2017, 10:38:52 am »
Under $20
Over $50
etc.
Agreed
Offline MacMeter
« Reply #98 on: August 14, 2017, 11:32:46 am »
Review it, curious to see what might make it worth 2-3x more then the average cheap pocket meters.
« Reply #99 on: August 14, 2017, 11:55:47 am »
OPINION NEEDED:
HY12P66
Just opened it at home and it's very nice!
GDT + PTC protection for the CAT IV rating.
Selectable auto power off and beep off.
