Author Topic: Pocket Multimeter Shootout  (Read 45281 times)
Offline EEVblogTopic starter
« on: July 27, 2017, 08:04:18 am »
This video has been hanging around for ages now, but I'm finally making preps to do it.
I have 8 pocket meters:
Amprobe   PM51A (Brymen BM22)
UNI-T   UT10A
SANWA   PM3
DER EE   DE-19S
HIOKI   3244-60
ANENG   AN8203
Digitech   XB-866
KYORITSU   1018H
The main requirement is true shirt pocket size with case and fixed leads, no removable leads.
Setting up a comparison spreadsheet.
Planing to make the video in two parts. One is a quick overview and summary of each meter (1-2 min each?) and declaring the winner(s). The other will be all the in-depth testing.
Comment invited.
« Last Edit: July 27, 2017, 08:07:38 am by EEVblog »
Offline Wytnucls
Re: Pocket Multimeter Shootout
« Reply #1 on: July 27, 2017, 08:37:57 am »
I think the UT10A has been discontinued, replaced by the UT120A and UT120C. Old stock might still be available online for a while.
Offline TheAmmoniacal
  • Country: no
« Reply #2 on: July 27, 2017, 09:10:34 am »
I suggest a scoring system, and deciding on a 'winner' at the end.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #3 on: July 27, 2017, 09:18:59 am »
I have the UT120A somewhere, but I havent used it for a long time. It just feels veey cheap and toy like. Apparat from safety concerns...
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
« Reply #4 on: July 27, 2017, 09:25:40 am »
Woah, they claim ETL certified?
http://www.uni-trend.com/productsdetail_1950_1100_1100.html
Offline The Soulman
  • The sky is the limit!
« Reply #5 on: July 27, 2017, 09:35:33 am »
Also asses the kink protection on the fixed (and as cheap as they could find 'em) test leads, that is a real week spot on these meters.
If you do find a "winner" send it over to joeqsmith and see what he thinks of it.  :P
Offline Wytnucls
« Reply #6 on: July 27, 2017, 09:54:29 am »
A and B models are definitely listed. Haven't seen the C model on the Intertek site yet. It is probably not listed because of its current ranges.
http://etlwhidirectory.etlsemko.com/WebClients/ITS/DLP/products.nsf/4c8700f3b75987a08525777700583333/1983b42d5046baa78625812900118263?OpenDocument
« Last Edit: July 27, 2017, 10:28:43 am by Wytnucls »
« Reply #7 on: July 27, 2017, 09:56:07 am »
A and B model are definitely listed. Haven't seen the C model on the Intertek site yet. It is probably not listed because of its current range.
Are any other Uni-T meters ETL listed?
I'm stunned that they would do this on a cheap pocket meter  :o
Offline ebastler
« Reply #8 on: July 27, 2017, 10:05:55 am »
Why would you make that a requirement? If removable leads make a meter more bulky, that should be scored as a negative. But otherwise, I think removabe (and hence replaceable) leads are a benefit. The fixed leads -- often without proper kink protection where they enter the meter -- are a reliability concern, and potentially a safety concern in my eyes.
Offline Wytnucls
« Reply #9 on: July 27, 2017, 10:10:08 am »
Plenty are. Especially the latest models:
UT 139/61/33/132/151/171/105/106/181
« Last Edit: July 27, 2017, 10:17:54 am by Wytnucls »
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #10 on: July 27, 2017, 10:13:07 am »
For me test leads need to be non remouvable for a pocket sized Meter too. But if they arent of good qulity and there is no realy strain reliev, they break.
Thats another thing I dont like about the UT120A. I have to find it and take a closer look at it. I hope dindt threw it away in the meantime.
  • Country: no
« Reply #11 on: July 27, 2017, 10:21:54 am »
The pocket meter I use is the Sanwa PS8A, always bring it with me.
Offline plazma
    • Homepage
« Reply #12 on: July 27, 2017, 10:26:03 am »
The Aneng looks like rebranded Victor VC921. The TrueRMS version is hackable witt extra buttons and UART output. I wonder if the Aneng version is as good.
« Reply #13 on: July 27, 2017, 10:27:35 am »
My shootout, my rules  :P
Offline ebastler
« Reply #14 on: July 27, 2017, 10:35:11 am »
Fair enough ;-)
Don't forget the "kink stress test" then -- maybe Sagan can help with that?  ;)
Offline Wytnucls
« Reply #15 on: July 27, 2017, 10:56:28 am »
The UT120 has a rubber grommet for stress relief.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #16 on: July 27, 2017, 11:07:12 am »
I dont remember it beeing good
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #17 on: July 27, 2017, 11:13:11 am »
Why?
It is as arbitrary as saying it must be red with a translucent plastic clamshell style case, and no transistor tester. None of which affect its pocketability. But if it does then score it accordingly.
A pocket multimeter goes in a pocket and is a multimeter. That's it.
In my opinion a meter that is very small and fits nearly everywhere. I think thats rather hard to achiev with remouvable leads.  Thats wy I want a pocket dmm with fixed leads.
Offline Wytnucls
« Reply #18 on: July 27, 2017, 11:29:09 am »
On closer inspection, it is more of a plastic retainer, molded tight on the leads to prevent stress on the PCB connections.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #19 on: July 27, 2017, 11:33:44 am »
From the OED Arbitrary: Based on random choice or personal whim, rather than any reason or system.
I'm still claiming fixed leads is arbitrary. And pocket multimeters don't need to fit nearly everywhere, just pockets.
Thats your opinion. I respect that.
« Reply #20 on: July 27, 2017, 01:56:30 pm »
Have you used a real pocket wallet type multimeter?
The entire meter plus the fixed leads fits in less volume than just the test leads of a removable lead "pocket" meter would take with all their tangled mess.
The following users thanked this post: dr.diesel
Offline Wytnucls
« Reply #21 on: July 27, 2017, 02:14:16 pm »
Can you please include the Fluke 867B in the shootout? It fits in my cargo pants pocket (Belt and braces required).  :-*
The following users thanked this post: rsjsouza, tooki, Scottjd, RissViss, Electro Detective
Offline ebastler
« Reply #22 on: July 27, 2017, 02:20:13 pm »
Looks like the perfect form factor, but it has detachable leads -- sorry!  :P
Offline Fungus
« Reply #23 on: July 27, 2017, 02:36:15 pm »
No Uni-T UT120C?
Best multimeter case ever...
Offline kalel
« Reply #24 on: July 27, 2017, 03:07:24 pm »
I guess the 4000 count Victor VICTOR VC921 matches the bill:
There's a similar looking Aneng (and a few other brands), but the letters on the display seem a bit smaller (might be just the images).
It's nice that these $10 pocket meters are 4000 counts. Edit: The Aneng is already included.
Among the cheapest (pocket meters, not 4000 count) is also a DT variant,
$4-5 But I guess this one isn't interesting.
The cheapest would be this one, but detachable leads, so no go:
« Last Edit: July 27, 2017, 04:20:32 pm by kalel »
