Thanks,
Yes the ribbon cable goes from the main board to a small PCB connector taped to the back of the screen. There is then a second cable going from this PCB into the screen. Getting to this did require extensive disassembly - removing the power supply PCB to get to the screws securing the front of the case to the steel casing. The small PCB tapped to the back of the screen has the cables glued in, I didn't muck around with these connections as they looked good but I guess the fault could be there? Ill take another look tomorrow. Will also check continuity of the cable thanks.
Thank you very much for your help, you have saved me from going off on the firmware tangent.
