I had the luck to get a Keysight DSO-X2024A at very good price and I am very happy with it.
There is one minor quirk I (long time Tektronix user) don't understand: When I move a beam
up, a
negative voltage is displayed. I would have expected a positive voltage. Of course (
) I read the manual, which says:
1 Turn the small vertical position knob to move the channel's waveform up or down on the display.
The voltage value momentarily displayed in the upper right portion of the display represents the voltage difference between the vertical center of the display and the ground level ( ) icon. It also represents the voltage at the vertical center of the display if vertical expansion is set to expand about ground (see “To choose "expand about" center or ground" on page 47).
Ah ja. What?
Why a negative voltage for a move in positive direction? Can someone enlighten me?
