Author Topic: Picked up a CSI1802X bench supply ($50, 0-18v, 0-2A)  (Read 11204 times)
Offline cellularmitosisTopic starter
« on: February 01, 2014, 05:26:44 am »
I saw this supply online for $50 and after seeing a couple of tear-downs and finding the schematic, I just couldn't resist.  I've got a few mods planned for this little guy :)
Website: http://www.circuitspecialists.com/bench-power-supply-csi1802x.html
Schematic: http://www.circuitspecialists.com/pdf/1802X_schematic.pdf
Previous forum thread: https://www.eevblog.com/forum/chat/insides-of-a-0-18v-2a-power-supply-the-csi1802x/
Tear-down I found on a blog of a similar model: http://pickandplace.wordpress.com/2012/06/08/qj1502c-15v-2a-power-supply-review-labornetzgerat-test-mastech-hy1502d/
LTZs: KX FX MX CX PX Frank A9 QX
Offline c4757p
  • adieu
Re: Picked up a CSI1802X bench supply ($50, 0-18v, 0-2A)
« Reply #1 on: February 01, 2014, 05:39:34 am »
I see they fixed some of the problems my identical-looking Mastech version had. Interestingly, that includes the frequency compensation networks. Glad I never found the problem with those... ::)
« Reply #2 on: February 01, 2014, 05:40:07 am »
First, a worst-case thermal test (leads shorted, amperage knob all the way up).
The hottest point I could find by probing with a type-k thermocouple was the head of the screw which secured the pass transistor to the heat sink.
Ambient temp at the time of test was 23C.
At the 5-minute mark, the pass transistor screw measured 72C.
At the 10-minute mark, the pass transistor screw had climbed to 82C.
I also measured the bridge rectifier (four discrete 3 amp diodes), which read quite a bit hotter at 93C (this surprised me a bit).
There was another transistor (a TO-220 D880Y) which read 68C.
I also measured the transformer case, but it was only 33C.  After powering it down I felt the transformer to confirm, and it seemed very mildly warm.
Offline c4757p
  • adieu
« Reply #3 on: February 01, 2014, 05:42:21 am »
I see the 65°C thermal cutoff switch in the schematic is just for show.
« Reply #4 on: February 01, 2014, 05:47:05 am »
One thing I really liked about this supply was the 1mA readout.  However, the single-turn pots are totally hopeless for dialing in an exact value.
Keeping in the spirit of the cheapest possible power supply, I gave it a little upgrade using the cheapest possible 10-turn pots.  Luckily they fit precisely into the existing holes, and they just barely fit next to the circuit board.  No drilling required!
This was a huge improvement in usability.  Now, I can dial in 20mA through an LED relatively easily.
One thing to watch out for: all of the screws are self-tappers directly into the plastic or sheet metal, so it is extremely easy to strip them out while performing mods like this.
edit: spelling
« Last Edit: February 01, 2014, 05:50:19 am by cellularmitosis »
« Reply #5 on: February 01, 2014, 05:48:24 am »
(Apologies for the incorrectly rotated photos, they are all rotated correctly when viewed on my laptop, so I'm not sure what I can do to fix that situation...)
« Reply #6 on: February 01, 2014, 05:57:22 am »
On second thought, the relay for the second tap kicks in around 6.6V.  I wonder if using a dummy load to draw 2A at the bottom of the second tap (6.6V) would be even more of a worst-case scenario for heat?  (18v-6.6v * 2A should be greater than 6.6v-0v * 2A, right?).
Offline GeoffS
« Reply #7 on: February 01, 2014, 06:05:29 am »
It seems to be a forum thing. If I download the images and view them they are the right way around.
Offline c4757p
  • adieu
« Reply #8 on: February 01, 2014, 06:06:55 am »
If they were taken with a phone - many (most? all?) don't actually rotate the image when you rotate the phone, they just stuff a tag in the EXIF data. Some viewers respect that tag and others don't.
Offline GeoffS
« Reply #9 on: February 01, 2014, 06:15:13 am »
Spot on. Images taken with an iPhone 4
They have the OP's GPS coordinates too  :)
Offline BravoV
  • +++ ATH1
« Reply #10 on: February 01, 2014, 06:21:45 am »
Missile location locked on....  >:D
Offline GeoffS
« Reply #11 on: February 01, 2014, 06:24:15 am »
Nice looking place but a bit close to the freeway  :)
Offline Napalm2002
« Reply #12 on: February 01, 2014, 04:39:37 pm »
I'm going to buy one of these power supply's. Can u give me the part numbers and where u purchased the upgraded pots?
« Reply #13 on: February 01, 2014, 07:58:35 pm »
Before you order the super cheap parts, keep in mind that I have been warned by other forum members that they are junk.  I will not be surprised if these fail in a month, but I'm ok with that, as I know not to use this supply to power anything expensive or precious.
Search ebay for "wxd3-13 10 turn".  You don't really save much until you order in quantities of ten (at which point they are $1.50 each).
Online Monkeh
« Reply #14 on: February 01, 2014, 08:02:36 pm »
Those pots are okay so long as you're exceedingly careful handling them and soldering.
Offline Napalm2002
« Reply #15 on: February 02, 2014, 01:47:36 am »
How many ohms? Is there a better source? Maybe a ill more expensive and more quality version? Of the ten turn pots I mean?
Offline Pasky
« Reply #16 on: February 02, 2014, 01:55:19 am »
Wow thank you for all this information, I'm tempted to grab one myself for $50.  I don't need anything over 12V, 1.5A anyways.
Before I pull the trigger, is there anything better within the same price range?
EDIT:
Actually, I just saw this:
http://www.circuitspecialists.com/csi3003sm.html
http://blog.circuitspecialists.com/product-review-of-the-csi3003sm-and-csi3005sm-dc-switching-power-supplies
0-30V, 0-3A.  Thoughts?
« Last Edit: February 02, 2014, 02:04:49 am by Pasky »
Offline rdl
« Reply #17 on: February 02, 2014, 02:10:11 am »
That is a switch mode power supply. Check the ripple spec. Okay if you can live with 200 mV p-p
EDIT:
Offline Pasky
« Reply #18 on: February 02, 2014, 04:33:16 am »
Ah yes, a switching regulator would cause too much noise for what I would be needing this for, thanks for pointing that out.
I think I'll grab the linear in the original post.  They have another one for $80 that does 0-30V and 5A, but I don't think I'll need anything for the small things I do.
Can anyone suggest some quality multi turn potentiometers for the knobs?  I don't wanna install something that will just fail within a few months  Thanks.
Offline mariush
Offline Napalm2002
« Reply #20 on: February 10, 2014, 03:32:10 am »
Can anyone tell me what the values are for the two pots? I would like to upgrade to decent ten turn pots. Can anyone tell me what the resistance values are so I can order quality pots.
Mike m
Offline Pasky
« Reply #21 on: February 10, 2014, 03:35:18 am »
From the pictures, they say 10K
Offline Napalm2002
« Reply #22 on: February 10, 2014, 03:40:59 am »
I guess that my dumbass should have zoomed in on the pictures!
Good looking out Pasky
Mike m
Offline Napalm2002
« Reply #23 on: February 11, 2014, 11:39:53 pm »
Just ordered one, can't wait to get it and play with it!
