Author Topic: Fluke PM6304 PM6306 PM9565 - DC measurement option board, project halted.  (Read 8202 times)
Online coromonadalixTopic starter
Hello @ll
I'm trying to revive this board and checking here if anyone would be interested to have a bare board or an assembled one ???  feedback's  etc ...
I have designed and routed a new schematic revision ... i'm in process of ordering 5 prototype boards and checking for errors if any.
In Canada   I can have all the parts at Digikey for around 120$ Can  for assembling  2 or 3 boards, and 30$ Can for 5 bare boards.  Few years ago this board was sold for 900 Euro ???
I'm waiting for an answer from a EEVblog member, if he would be kind enough to ship me his board to help me counter check my version, maybe send his rs232 adapter option too, to copy / dump the firmware and make it available.
I'm not trying to take huge profit, but enough to cover material and parts, and add the missing options for my LCR Meter.
I work in a pcb assembly company, i have access to smt assembly machine and solder posts ...
« Last Edit: October 09, 2019, 09:43:17 am by coromonadalix »
Offline BravoV
  • +++ ATH1
Re: Phillips / Fluke PM6304 PM6306 PM9565 - DC measurement option board
« Reply #1 on: April 12, 2017, 03:30:22 am »
Count me in, check your PM.
Offline BravoV
  • +++ ATH1
« Reply #2 on: April 12, 2017, 03:33:59 am »
So board wise, I assume it will look similar to this ?
Photo courtesy of HighVoltage from this -> post
Edit : Calling out HighVoltage for helping us more close up photo of his board.  ^-^
« Last Edit: April 12, 2017, 03:41:01 am by BravoV »
Offline HighVoltage
« Reply #3 on: April 12, 2017, 06:27:48 am »
I will be sending a RS232 board and a DC board to coromonadalix by airmail next week, for reverse engineering, to get this project going.
May be I can take some pictures before I send them out.
« Last Edit: April 12, 2017, 06:39:33 am by HighVoltage »
Offline BravoV
  • +++ ATH1
« Reply #4 on: April 12, 2017, 07:20:55 am »
Yay !!!  :clap:
A macro close-up of that board at both sides will be really helpful to clone this board, thank you.  :-+
« Reply #5 on: April 12, 2017, 10:33:00 am »
@ bravo  similar look  but not identical, since i will use dual op27 amp (opa2227) instead of single ones,  reduced parts count, the change made a 25$ less in  parts, the size is now good, it should fit ?
Here's a look of the pcb  2-3 posts down this one
I have used radial decoupling capacitors for the moment, to help the second layer, the layer thickness or width size may be too small in the power lines. And I'm limited to 2 layers unless i pay more ... it double the price for a 4 layers 1 oz pcb's
IF high voltage send me his boards,  i will compare them before producing ... i have only 3 missing supply traces from the SM for a chip, i could put them and cut them if needed ??
I would like to build a potential list of buyers ?? for around 150$ CAD each,  the chips are the one who cost a lot,
The 1% smt resistors are around 0.35$/each for 36 parts count, and the resistor network chip is around 8$ ???
I used smt 1210 size to have possibility of the originals mma0204 series resistors ?? i'm not able to have all the values here in 1%.
The strange thing with the res network  is some kind of thermal coupling between the 8 resistors, they are in serial (4x1k) with an common point, i can't see another functionality than this, instead of 2 single axial resistors of 4k thermally glued together ???
LIST:
#1 is @bravo
« Last Edit: April 13, 2017, 04:10:40 am by coromonadalix »
Offline BravoV
  • +++ ATH1
« Reply #6 on: April 12, 2017, 10:37:41 am »
Great  :-+
Btw, you can upload that file or any other supported types as an attachment as this forum, just look below the dialog box you're typing, it will be much better than external hosting, especially the free ones, just a suggestion.
Offline BravoV
  • +++ ATH1
« Reply #7 on: April 12, 2017, 10:43:05 am »
Just noticed the board's shape, as there is a extruded part, are you planning to do plain rectangle ?
Not a big deal though, at least for me, just curious.
« Reply #8 on: April 14, 2017, 11:57:17 am »
Parts ordered,  have to make an final check on the pcb ... should arrive before the end of the month
Offline BravoV
  • +++ ATH1
« Reply #9 on: April 14, 2017, 12:22:05 pm »
Have you received the board from HighVoltage ?
Offline HighVoltage
« Reply #10 on: April 14, 2017, 01:10:29 pm »
That would be faster than light!
I just came back from a business trip and will send them out on coming Tuesday (Monday is a holiday) by airmail.
Then it should take one week, I guess.
Offline BravoV
  • +++ ATH1
« Reply #11 on: April 14, 2017, 01:15:33 pm »
LOL , ok, hopefully they will arrive as planned.
Btw, please take a close-up/macro shots of the whole board at both sides if its not troubling you too much, TIA.
« Reply #12 on: April 20, 2017, 01:31:57 am »
Here's the final version ?? still checking if all is right before ordering, added some pads in RN111 for thru hole resistors ...
In the service manual, there was some thru hole added parts  in figure 31,  the green board picture we see has the revisions integrated on the board.
For the four thru hole parts, 1 inductance and 3 resistors i have to wait for highvoltage to ship me his board ??? and correct them later ??? It should be ok like this too and still be functional.
« Last Edit: December 14, 2021, 11:33:56 am by coromonadalix »
Offline HighVoltage
« Reply #13 on: April 20, 2017, 10:51:48 am »
OK, I am in the lab now and removed the DC and RS232 boards and can send them both out today.
Next I will take some high res pictures for you of both boards.
Offline HighVoltage
« Reply #14 on: April 20, 2017, 11:03:19 am »
DC Board
Front Pictures
Offline HighVoltage
« Reply #15 on: April 20, 2017, 11:08:22 am »
DC-Board
Back Pictures
Offline HighVoltage
« Reply #16 on: April 20, 2017, 11:14:23 am »
RS232 Board Front
Offline HighVoltage
« Reply #17 on: April 20, 2017, 11:18:59 am »
RS232 Board Back
« Reply #18 on: April 25, 2017, 11:30:27 pm »
Waiting for Highvoltage boards to continue this thread ....
Offline HighVoltage
« Reply #19 on: April 26, 2017, 08:41:05 am »
They are shipped out and hopefully arrive at your place in a few days.
« Reply #20 on: May 06, 2017, 03:00:47 am »
Boards just received,  dump the rs232 interface FW and  checking my pm9565 design against the real pm9565 from Highvoltage
Edit : rs232 interface
The dump is made in 3 copies, check ok ??  its a ST m27c1001-12c1,  d109  (part number not listed ???)
The cpu is an OTP 80c652 (rom less)
Edit 2 : there is some wire rework on 2 chips near the cpu
Edit : DC Option pcb
Highvoltage board is an revised version of the photo "schematic figure 31" page 147
« Last Edit: May 13, 2017, 01:56:07 pm by coromonadalix »
Offline BravoV
  • +++ ATH1
« Reply #21 on: May 24, 2017, 06:04:43 am »
Any updates ?  :popcorn:
« Reply #22 on: May 24, 2017, 10:15:39 am »
It is a nightmare to find the original mma0204 resistors, Newark ask a minimum of 3000 parts to buy  for 3 values total of 9000 resistors total of 380$  outch
In smt1210 sizes, i miss only a value of 4.64 megs, 6-8 weeks of delay ???
I never tought it would be this difficult to have precision parts ...  the boards are ready to be ordered
Since the pm6304 and 6306 inside photos are shown,  i'm sure the board will fit, they are identically positioned, and the clearance will be ok,  not totally sure of the 6303 model ..  my boards are almost 1 cm too high, the width is ok.
Tried to shrink further the board, but the software has begun to take too much time to place and manage the parts (clearance, track width, parts spacing etc..), i helped it by taking thru holes decoupling 0.1uf capacitors instead of the smt ones.
I can only make 2 sided boards, if i do a 4 layer one, the costs are jumping up really fast.
« Last Edit: December 14, 2021, 11:34:28 am by coromonadalix »
Offline klaus11
« Reply #23 on: June 13, 2017, 09:01:59 am »
A quick look at EBay Europe's, there seems to be a lot of MMA0204.   :-//
HP3458A, HP3245a, Keithley 2000, Fluke 87V, Rigol DP832, TEK TDS5052B, HP33120A
Offline Neomys Sapiens
« Reply #24 on: October 09, 2019, 02:20:25 am »
It's been a time, but the way this thread ends in mid-air, left me wondering: were those boards actually made and did they work? Are there available parts or PCB files?
