Author Topic: Philips PM3295 and PM3295A  (Read 7706 times)
Offline david69Topic starter
« on: February 21, 2016, 09:48:13 am »
Hi, I suppose that "A" version is newer and use inverter for
LCD backlight, older version used graticule? I missed backlight
on my PM3295 :( and I can`t find any source for LCD into scope
There is inverter 300VAC in service manual, but I miss this
inverter and light plate under LCD. There is anything which should
be shine :( Thank You for explanation..
Re: Philips PM3295 and PM3295A
« Reply #1 on: March 04, 2016, 02:30:45 pm »
Here are pictures with display and control unit. Supply 13,8V
for display is OK :) But I don`t have orange backlight :(
The driver for LCD is PCE2111
« Reply #2 on: March 05, 2016, 05:41:52 pm »
Can be there LED driver in PCE2111?? as AN for new LCD driver??
Thanks...
« Reply #3 on: October 21, 2016, 05:30:31 am »
I was looking into bad capacitors in supply in 5VDC digital
section...
Offline tautech
« Reply #4 on: October 21, 2016, 06:17:01 am »
Here I was thinking this was just a CRO and wondering what on earth you were going on about a backlight.  :palm:
So yeah, there must be one behind all the LCD panels.
Service manual:
http://elektrotanya.com/philips_pm3295_service_manual.pdf/download.html
30 Mb 322 pages
Wait for "processing" to change to "get manual"
Some stuff seen @ HQ cannot be shared.
Offline tautech
« Reply #5 on: October 21, 2016, 06:36:14 am »
P 47 in the manual has the LCD circuit description along with the supply to it is derived from a +13.8V rail.
It's nominal 4V is ambient temp referenced by transistor V101 to somewhere in the range of 3.5-4.5V.
Is this ^ working as expected?
« Reply #6 on: November 23, 2016, 12:28:58 pm »
Yes, collector V0101 BCW33 has 4,25V and C101 R113 is
RC for oscillator PCE2111, I have there step down ramps?
I have change BCW33 without efect, no CRO?
Offline leogala
« Reply #7 on: February 16, 2017, 08:31:50 am »
I was thinking to replace the lcds of my PM3295A with nice 0.96'' OLED displays available for a ridiculous price on aliexpress. Shouldn't be difficult to interface them with the serial protocol of the led driver, just a bit of reverse engineering on the meaning of the bits.... Anyone interested in the project ?
Offline leogala
« Reply #8 on: March 07, 2017, 04:34:55 pm »
Done ! Upgraded to OLED with the help of an arduino, less than 20$ in total. So cool !  :-+
The following users thanked this post: tautech, tooki
Offline mvdswaluw
« Reply #9 on: March 07, 2017, 04:54:18 pm »
Wow, nice professional look!
Offline cvanc
« Reply #10 on: March 07, 2017, 05:04:17 pm »
That is absolutely badass.  Well done!
Offline tautech
« Reply #11 on: March 07, 2017, 07:36:09 pm »
Very nicely done, congrats.  :-+
If you took some time to document the conversion with some pics and code if you want to share it....maybe best in another thread with links to this one.....anyway it could be of great help to others.
Offline cheeseit
« Reply #12 on: March 07, 2017, 09:10:07 pm »
Very nice! :clap:
+1 on documenting this.
« Reply #13 on: March 15, 2017, 03:40:38 pm »
it is very nice! but You must have different firmware ??
I can`t set Your screen with displayed frequency "kHz" ACvoltage
and etc... So, can I look for newest firmware and change it??
« Reply #14 on: March 15, 2017, 04:04:56 pm »
my settings, no orange ?backlight?
Offline leogala
« Reply #15 on: May 03, 2017, 06:50:41 pm »
I reverse engineered the serial protocol by means of an Arduino. Then I implemented the parser on an Arduino mini. If someone is interested I can provide the arduino c source files, I've not documented the protocol but it works perfectly.
This is the link to the displays I used.
Offline tautech
« Reply #16 on: May 03, 2017, 07:21:07 pm »
Please do. It helps those that might find this thread in the future and need the same solution/fix.
Offline leogala
« Reply #17 on: May 05, 2017, 08:12:08 am »
Ok, I opened a new thread concerning my upgrade.
see: https://www.eevblog.com/forum/projects/pm3295a-oled-upgrade/
