Author Topic: PEAK DCS75 PRO, virtual machine (windows) in VMware Fusion on OSX  (Read 1271 times)
Offline MBN65Topic starter
Hi!
I'm running VMware Fusion om my Mac and most tings work's but not my DCA75 Pro.
The Atlas software can't detect the device.
The device shows as "unknown device" in "device manager" in windows 11.
Any one got this to work?
Offline dibro
Re: PEAK DCS75 PRO, virtual machine (windows) in VMware Fusion on OSX
« Reply #1 on: June 02, 2023, 05:33:18 pm »
I have also a DCS75 Pro and never got the software working under Linux-wine or in virtual-box with windows 7 and 10.
Very disappointing.
« Reply #2 on: June 02, 2023, 08:26:39 pm »
Hi!
Have you asked Peak for help ?
They are members here:
https://www.eevblog.com/forum/profile/?u=84715
You could also try their Support webpage or their tech assistance:
https://www.peakelec.co.uk/acatalog/peak-product-support.html
technical@peakelec.co.uk
2 minutes with Mr Google brings you these results.....
Offline Paul Ed
  • …try, for who knows what is possible? —M. Faraday
« Reply #3 on: June 15, 2023, 02:17:18 pm »
Hello Magnus, in short Yes! It does work:-
Hi!
After reading carefully the included User Guide (dca-pro-user-guide-en.pdf) and following it as closely as possible:
 - thus NOT plugging in the DCA-75 Pro until after all the VirtualMachine WIndows/.Net/USB drivers/etc. had been installed
 - ensuring the "Connect to Virtual Machine" when prompted by VMware Fusion after pluggin DCA-75 in
it all "just worked"
Here are a few screenshots to show the install then the application running drawing nice curves...
« Last Edit: June 15, 2023, 02:24:52 pm by Paul Ed »
The following users thanked this post: RAPo
« Reply #4 on: June 30, 2023, 05:15:09 pm »
Hi!
Thank's for your tips.
I think I have tried it just like this with no luck.
Will try again.
Offline neuhauser
« Reply #5 on: July 31, 2024, 11:48:45 pm »
Hey guys. It was working on qemu and virtualbox. You had to bring up the transfer usb device in the virtual machine menu, plug in the peak, and select it from the menu within 5 seconds after it popped up to get it to transfer to the virtual machine. The last DCA firmware update seems to have broken the linux acp standards and won't allow it to be transferred. Gives timing and can't reset device errors in the linux acp logs.
