Author Topic: Pamela Anderson Hidden in Lecroy Wavepro Oscilloscope Firmware  (Read 25314 times)
Offline james_s
Re: Pamela Anderson Hidden in Lecroy Wavepro Oscilloscope Firmware
« Reply #50 on: December 30, 2017, 06:20:38 am »
Knobs slang for breasts?  :wtf:
The floppy drive makes me laugh. Did they really ever use it when it was even being developed? One of the blokes I work with has an Agilent E5062A network analyser on his desk. It's got a floppy drive whereas the one I've got is the newer 5061B and hasn't. Every now and then the floppy drive seems to check whether there's a disk in the drive and causes the entire system to hold for about 5 seconds. Drives him nuts.
We have a couple TDS5000 scopes at work that have floppy drives, I use the drive somewhat regularly, it works fine. It's not as convenient as an SD card but at the time the scope was made floppy drives were still in widespread use. That LeCroy looks about the same age.
Offline ivaylo
« Reply #51 on: December 30, 2017, 08:19:52 am »
Why not let @azalys let them know at twitter?
Offline ezalysTopic starter
« Reply #52 on: December 30, 2017, 08:25:30 am »
The fla file is a loader with zlib compressed firmware. It appears to set up the caches and mmu and other things and then it decompresses the image and jumps into it... nothing too fancy.
Offline Fungus
« Reply #53 on: December 30, 2017, 06:21:28 pm »
Doesn't it occur to him to, ummm, leave a diskette in the drive?
Offline mc172
« Reply #54 on: December 30, 2017, 10:24:38 pm »
It makes it worse. It tries to read what's on the disk. :palm:
Offline shteii01
Offline martinator
« Reply #56 on: December 31, 2017, 09:26:51 am »
Maybe there is a problem with the autorec.sta file? It could be looking for a machine state that was originally on drive a:
Offline darkstar49
« Reply #57 on: December 31, 2017, 10:09:44 am »
I'm pretty sure the mentioned emulator model doesn't fit, as Lecroy only used slim line floppies... but anyway, should be discussed in another thread, if needed... as not much related to this one...  ;-
Offline timb
    • timb.us
« Reply #58 on: January 01, 2018, 12:58:06 am »
You’re right. Based on some of Pamela Anderson’s own home movies, it’s clear she much prefers hard disks over floppy disks. Very, very large hard disks. *Rimshot*
Offline tv84
  • Country: pt
« Reply #59 on: January 01, 2018, 11:26:36 pm »
I was just poking around in the firmware image and found an easter egg. Here's how you reproduce it.
If you have the following firmware image... say from the Lecroy yahoo group. It's titled "Wavepro 9XX and DDA260 Firmwave V9.3.0 (Latest)"
$ md5 ./vxfusion.fla
MD5 (./vxfusion.fla) = c6bdcdc72ee55bc5d1ae725c657ced51
At an offset of 48465 there's a compressed image.
dd if=vxfusion.fla skip=1 bs=48465 of=data.z
Now you can unzip this any way you like... I used gzip with a prepended gzip header
$ printf "\x1f\x8b\x08\x00\x00\x00\x00\x00" |cat - ./data.z |gzip -dc > data.raw
gzip: invalid compressed data--crc error
CRC fails, but whatever. Now, at offset 4318044 there's a jpeg header. Curious!
0+1 records in
0+1 records out
1069348 bytes transferred in 0.001037 secs (1031310783 bytes/sec)
and you get the following image:
https://imgur.com/a/LOnOO (NSFW)
The compressed image is a complete ZLIB block from [0000BD51-001D0EDA] and, as such, has no CRC32. It has an ADLER32 checksum (in this case: 6E569D7E).
Nice find!
Offline CJay
« Reply #60 on: January 02, 2018, 07:34:55 pm »
Hmm, an HTTP daemon - does that model have an ethernet port on it?
I'm not sure you should try poking an ethernet cable into models, they probably won't like it
Online The Soulman
  • The sky is the limit!
« Reply #61 on: January 02, 2018, 08:55:47 pm »
As long as they don't encounter PoE.
Offline darkstar49
« Reply #62 on: January 02, 2018, 09:38:19 pm »
as already said, not too sure about the http daemon, but if someone has a better explanation, he/she's welcome...  ;-)
here the (most probably only) function where the image is referenced, no need to be an assembler, nor a web expert to recognise some known stuff...
Offline blacksheeplogic
« Reply #63 on: January 02, 2018, 10:13:45 pm »
Not well hand written Power assembler. Either the person who wrote this was inexperienced in Power assembler (new to the team at the time).
Offline darkstar49
« Reply #64 on: January 03, 2018, 12:12:13 am »
From (that and) other functions around that one, I’d tend to suspect a C compiler... the way registers are used is everything but ‘intuitive’ or ´natural’... and there are often  unnecessary register saving ops, which would be rather unusual for hand-written assembler...
« Reply #65 on: January 03, 2018, 12:49:03 am »
For a non-leaf function the stack frame has not followed convention, it's also be grabbed early creating an unnecessary dependency (not typical of a compiler), the use of r29 & r3 is peculiar even for non-optimized output.
Offline macboy
« Reply #66 on: January 03, 2018, 03:18:22 pm »
This is hilarious. I have one of these scopes (WavePro 960) with the LAN card. I'll have to check the firmware version and try to figure out how to get the http daemon to serve this.
Offline darkstar49
« Reply #67 on: January 03, 2018, 05:09:35 pm »
Keep us posted !!!
If it doesn’t reply on standard ports, try to perform a portscan to see what ports are active...
Offline JustSquareEnough
« Reply #68 on: January 04, 2018, 12:10:43 am »
No response to Dave's lecroy tweet ? I couldn't find it when I searched but saw it come out when he tweeted it...
Offline videobruce
« Reply #69 on: January 15, 2018, 10:24:43 pm »
You guys have way too much spare time...........................
Offline NiHaoMike
    • Facebook Page
« Reply #70 on: January 16, 2018, 05:06:19 am »
I can name a model who really likes Ethernet - Joanne Chiang. Of course, that's because she's a gamer and everyone knows gamers like Ethernet way better than Wifi.
Somewhat back on topic, I once embedded a picture of my friend Allie Moore into an OpenWRT image I created for another friend's WRT54G, accessible by opening "eegg.html" on the router IP. I don't think he ever found it.
Offline Berni
  • Country: si
« Reply #71 on: January 16, 2018, 06:08:43 am »
Inside the software for Keysight Infiniium scopes i found a picture of Jesus. :-+
It is hidden inside the main application exe file as a .NET resource. No idea if the software can be made to actually show the photo but the image file is certainly in there.
Offline darkstar49
« Reply #72 on: January 16, 2018, 06:38:29 am »
...'not too sure those who found it were looking for that sort of info...   >:D
Offline Berni
  • Country: si
« Reply #73 on: January 16, 2018, 07:24:22 am »
Well i did have a good reason for it. My scope lost some sample memory size after updating the software from the ancient version that came on it to the latest one.
Oh and Keysight also seams to be internally naming all the Infiniium scopes after dinosaur species, apart from one that's codenamed Toaster.
Offline darkstar49
« Reply #74 on: January 16, 2018, 07:52:02 am »
...'didn't have any problem with that... just saying that those who tear firmware images apart are typically not looking for sexy images, and that the whole story is thus not about having too much 'spare' time...
