Here is an LTspice mode that represents the circuit on AN61:
The flux in the core is modelled by summing the ampere turns in the two windings.
The bridge in AN-61 is modelled by the Thevenin equivalent circuit.
The circuit works by nulling the flux in the core.
Modeling ResultsAC response
Step Response - Transient Domain
Fast Step Response
I have attached the LTspice model.
You can play with the parameters in the model to determine the sensitivity to change.
Regards,
Jay_Diddy_B
AN61 model.asc (2.61 kB - downloaded 76 times.)
