Unless you are massively oversampling, there is no such thing as the 'zoom and enhance' that you see in films.
Why wouldn't you massively oversample if your sample rate allows for it?
That seems like a default sane behavior if you have the sample memory for it.
100MS/s offers plenty of opporunities to oversample when you're zoomed out a bit (I find it's rare that I look at the signal at the very limits of the device's sample rate)
Even this scope oversamples teeny bit by default (two samples per pixel on 1080p screen), but limited memory lets you zoom in one step before there's less than a sample per pixel - thus zooming in more would be pointless.
Similarly to zoom out from captured signal, you are not limited by sample rate, purely by sample memory.
5k memory is barely enough to fill a 4k screen to have a sample per pixel.
Of course you can't zoom out. Neither can you zoom in. 5k memory simply does not allow for that.
You can't zoom out from a captured signal at all, because well.... that would require some memory, and this thing has barely any.
I apologize I lost my temper a bit, that "in the films" remark really got me LOL. You can do everything like in the movies and more, including time travel to past if you have the memory for it darn it(or bandwidth to stream it over USB at full speed to a computer that has bountiful memory)!
One of the signals I'm looking at has noise spikes roughly every 500ms/1s (those periods can't be captured by edge trigger since the amplitude of the noise is the same, just way more of it). Precise timing of which I can't tell...... because it doesn't have enough samples.
For other signals and LDOs I can see that 3.3v LDO greatly amplifies noise spikes coming from USB VBUS at ~90kHz and no other aperiodic spikes. So no issues analyzing signals of that type.
I'm sorry that the 'zoom and enhance' got to you, but in this situation it really is quite apt. As you said yourself of course you
can massively oversample, as long as you have the memory to do it. The trouble here is that you can't afford that amount of memory and still meet a low price point in a USB scope.
You need to read more of the thread to understand the architecture of the 1022. Unlike competitors of the time (and many since) it implements all of the core functionality in an FPGA. This allows the solid hardware triggering and other features. The 5k buffers are implemented inside the FPGA. Moving to an external RAM would require a larger pin count FPGA that would blow the budget. As it is, Owon have changed the FPGA something like five times over the life of the 1022 in order to cope with supply and pricing changes (check out the firmware folder in the S/W). Added to that, it would increase power consumption, requiring an external PSU or USB power bodging, there would be a lot more data flying about so you would lose the galvanic isolation that protects you from blowing up your PC, you would also lose the fast screen update rate and snappy response that you don't get with something like a Hantek USB scope.
I've designed loads of high volume consumer products and can tell you that at this end of the market, every cent in the BOM cost matters. If you miss your niche, where you please 90% of your customers for the price, then you don't get to sell.
Owon do produce a range of higher spec USB scopes with 5/10M with higher sample rates, 4 channels etc. but you are talking several multiples of the 1022 price. mikeselectricstuff (member) did a video review of one of the 4 channel models (3104) and liked it. It's ideal for sticking in a slim bag when traveling (which he does a lot) but price wise, they don't stack up well against equivalent desktop scopes, so never achieved the same degree of traction. As I said, the 1022 dates back to 2015 (it was an unknown back then and I think I was the first to risk a teardown and review). Time moves on, but it's still a solid performer for a lot of people on low budgets / portability / space constraints.
Sorry, but I'm beginning to feel like I'm doing your research for you. If you want something with a combination of features that matches what you want then you are going to need to develop deeper pockets or take risks (I'm assuming the reason you even looked at the 1022 instead of one of the new range Siglent or Rigol benchtop is shallow pockets).
You really need to do some detailed research on some of the options you listed in reply #801 and see whether the feature combinations, s/w quality (presence or absence of bugs) meets your requirements. Maybe take some risks on quality versus price (there are bound to be compromises!), and pass the 1022 onto somebody else, you won't struggle to make a profit on the price you paid for it.
P.S. Just looking at the options you listed, the Hanmatek / Owon ones only have 10k record length, hardly an improvement on the VDS1022. Only the Hantek has buffers in the Megasamples range, 8M?
EDIT: You piqued my interest with the devices you listed (in fact I spent most of the day looking). I don't know where you got your pricing, but in the UK, both the Hantek DSO2C10 and the Owon SDS1102 are currently around 210eur (making the price differential with the VDS1022I considerable, >2x).
Looking at the options, the Hantek has some good reviews and seems to be the winner on features, e.g. protocol decoding (although that seems to have issues like buffer length shrinking to 4k when decoding and not being able to decode stopped waveforms), It doesn't come close to what you can get with a <10eur LA clone and Sigrok anyway, unless you need higher frequencies. There seems to be an issue with low level measurement accuracy too.
I wouldn't touch the Hamatek DOS1102 over the Owon SDS1102, 20mV/div means minimum of 200mV/div with a x10 probe - not sensitive enough!
As far as Owon VDS1022 vs SDS1102, depending on max frequency requirement it's not as clear cut as I assumed for USB vs bench. If you need 100MHz bandwidth, then the SDS is the only option, if 25MHz is sufficient then it's not as clear cut. Stuff I observed from the specs and video reviews... The SDS lacks the number of trigger options of the VDS, it only has 2 BNC inputs (no external trigger input / output or pass/fail functionality which can be very useful on a 2 channel scope). The 10k buffer vs 5k seems fairly academic when comparing with multi Msample scopes. The SDS does have a PC app, but it is so slow as to be unusable, disappointing. Lastly, you need to store waveforms to a USB stick for transfer to the PC rather than just clicking the save button to save a waveform to the PC. I asked myself whether I would buy the SDS while owning the VDS (I've been wondering about a new scope) and I honestly don't think I would. Not unless I really needed the bandwidth and could live with the compromises. I don't have a UK price for the SDS1104, but I might buy one of those if I needed 4 channels and it wasn't much more expensive than the 1102. This comparison surprised me, I assumed the SDS would at least have everything that the VDS does. I haven't even touched on display size and UI.
Would I personally buy the Hantek? Maybe, but I would worry about bugs and functionality issues (I don't know what, if anything has been fixed in F/W since the reviews I saw. They look a bit fundamental. At least you get the massive buffer for non-decode stuff and get back the external trigger. Again, bandwidth requirements might make it a no brainer.
I think with both of them, I would have a nagging regret that I hadn't bought something Siglent, the SDS1102CML or higher, but those are in an entirely different price bracket still.
Just my thoughts anyway, Ymmv.
