I think about getting this (vds1022I) scope until i can afford something serious and its a shame there is so little documentation and almost no experiences about it.
The software looks better compared to other usb scopes and i already downloaded it to look at the functions and the files.
It looks like it runs in java and there are several *source.jar files in the plugins directory, which do contain .java source files.
Maybe it can give some hints on how to interface the scopes.
I wonder if they accidentially included their source code in the program?
Can someone take a look at the program (VDS_C2) and the files in the plugins directory to see if that might be a possibility to interface those scopes or if the files are worthless?
Especially the "com.owon.vds.foundation.source_1.0.0.jar" looks like it contains the usb communication stuff and most of the functions of the program.
The "org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar" is what actually starts the whole program and can be run directly. Sadly it seems like no source for this exists, but it looks like it only loads other parts of the program.
*edit*
Tried to rebuild some classes using the sources i found and it seems possible.
Also as the program is java it runs perfectly fine under linux if you don't use the launcher but i am not sure what the launcher actually does and how hard it is to actually get the scope running under linux.
