I've also received the scope. Tested and it works well with florent software.
The only thing you have to do in addition to following instructions on florent github (install java JRE) is to get 'Zadig' to install USB-drivers for the device.
First impressions - It will definitely be useful (especially as educational tool), but I would have been pretty disappointed if I paid the full price for it (which is in 70-80eur range).
Right now I'm just hooking it up to everything and measuring things, such as looking at various LDOs and switching mode regulators on various MCUs I have.
5k record depth is just not good at all. Can't really zoom out or zoom in any captured signal to see more.
For full price it's really old & outdated and I would not recommend it. Actually any of the oscilloscopes with record length below atleast 1M is out of the question.
Oscilloscopes is just one of those things that are not possible to cheap out on.
I'll write a more indepth review some week(s) or month(s) later after I've had more time with it.
I'm puzzled by the Zadig reference, It's not something I've ever had to do as both the stock S/W and Florent's S/W install the driver. You got me thinking that maybe I had always installed Florent's after the stock S/W, but then I remembered I had recently (only) installed his S/W on a Win7 VM under linux and it worked fine (the JRE is of course required). The Linux version works too of course.
Just looking back the start of the thread, my original review and teardown was in 2015
and the model is still available. It carved a niche at that price point that has pretty much survived ever since, based on price/performance. The only 'competitor' at the time was the Hantek USB range, that had
no buffer, well maybe a couple of hundred bytes in the EZ-USB microcontroller (despite what the spec says) and relied on streaming everything in real time and triggering in PC S/W. There are certainly low end handheld and bench scopes coming down the line now but still not to the same price point (unless you get really lucky on Ali with some less known/unknown brand). The only real competitor in the USB space and H/W quality, as I mentioned previously, is the significantly more expensive, Pico 2204A. This arguably has much more flexible S/W (shared with the higher end models), but when you look at the fine print, it drops to 50Msps when you turn on both channels and it still has only a 8k samples buffer (I'm not clear whether this is per channel or shared, like the sample rate). I don't know of any low end USB scopes that have 1M buffers.
The 5k (per channel) buffer is certainly a limitation, it makes you go back to 'traditional' scope usage techniques - if you want to look at more detail of an edge, you increase the timebase and trigger on that edge rather than trying to zoom it up from a long capture (in your previous post, you mentioned several seconds). Unless you are massively oversampling, there is no such thing as the 'zoom and enhance' that you see in films. It's instructive to go into the display menu and switch from 'Vector' to 'Dots' to get an actual picture of how many samples the display of a particular waveform feature is being based on. If there are too few, you need to go to a faster timebase.
I was a unclear, from your previous post, about your requirement for capturing a couple of seconds of a fixed frequency (20-40-60kHz). If you are looking at one or more logic signals, a <$10 logic analyser, streaming to the PC is definitely the way to go. Again you need to fall back on traditional methods - the scope was used for evaluating the analogue domain integrity of a logic signal (rise and fall times, overshoot, crosstalk / ground bounce etc) and then the logic analyser for long captures and data decoding.
Looking forward to your more in-depth review anyway. Don't forget to pick up the keyboard shortcuts, they speed up the UI considerably.
