But if you simply use it with a notebook only on its battery, unplugged from the wall, it's also effectively isolated, no? (though not wireless
Yes that would isolate the scope and PC from earth ground. But c'mon now, where's the unneeded complexity in that !
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
I got my VDS1022 delivered today. Thumbs up to Saelig, I put the order in on Fri and it came (free shipping) 5 days later.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I wanted to put up a somewhat obvious chart of sampling rate vs horizontal time setting in case some people didn't realize that they're tied in a DSO. In particular with only 5k samples/chan of storage, there's only so long it can collect data before that memory is full. And so to "see" a longer display means a slower Sa/s rate. And that means less than the full bandwidth is available as those rates.
5ns/div 100MS/s
2us/div 100 MS/s
5us/div 50MS/s
10us/div 25MS/s
20us/div 12.5MS/s
50us/div 5MS/s
100us/div 2.5MS/s
200us/div 1.25MS/s
500us/div 0.5MS/s
1ms/div 250kS/s
2ms/div 125kS/s
5ms/div 50kS/s
10ms/div 25kS/s
20ms/div 12.5kS/s
50ms/div 5kS/s
................. trigger to auto mode, no single shot available
100ms/div 2.5kS/s
200ms/div 1.25kS/s
500ms/div 0.5kS/s
1s/div 250S/s
2s/div 125S/s
5s/div 50S/s
10s/div 25S/s
20s/div 12.5S/s
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
50s/div 5S/s
100s/div 2.5S/s
I wonder how Owon splits those half samples ?
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
I had a brief chance to sniff the USB link and what I've seen so far is (I think) that the program on the PC sends a set of 3 commands to the scope HW. Each of these gets a 5 byte response except for the last one. If the HW is not "ready" (buffer not full ?) then a "busy" response is sent. IF the HW is ready then there's a 5216 byte message. The 1'st hundred or so bytes seem to be some header of some sort, the remainder appears to be the sampled data.
In this case I had only a single channel on, digitizing the 1kHz test signal. The scope was autoset to some ?? V/div vertically, near zero offset and 50kSa/s. One period of that data looks like ;
3C 3D 3C 3C 3C 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3E 3D
00 01 01 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 FF 00 00 FF 00 00 FF 00
I interpret those 50 bytes as 25 samples of 0 or -1, 25 samples of 61 (+/- 1). The numbers make sense if the scope sends a 2's complement number, -127 to +128 for it's 8 bit sample. The 50 samples make sense for a 1 msec period sampled at 50kSa/s (-> 50 Sa/ms). The 50% DC of the test waveform is obvious.
So sometime this weekend I'll vary the sample rate and turn on the other channel just to see what I can see via the sniffed USB. I'll post my results and thoughts here, if anyone is interested and the OP doesn't mind the "hijack" of his thread. And if I can how to get the multiport to output, I'll measure the waveforms/sec update rate vs horz time setting, which should be good for a laugh. From the USB timestamps for the above, it was ~ 14 ms between 2 full data packets or ~71 wvfrms/s.
