Author Topic: Risetime measurement on Rigol DS1052E  (Read 4074 times)
Offline janengelbrechtTopic starter
    • JP-Electronics
« on: November 27, 2014, 08:44:01 am »
Just to be 100% sure: Does the Rigol DS1052E measure risetime the normal way 10% and 90% of the step height ?
This frame seems to indicate so....but if you intelligent guys could confirm it...im a happy man :P
http://janengelbrechtpedersen.dk/risetime.png
Re: Risetime measurement on Rigol DS1052E
« Reply #1 on: November 27, 2014, 08:55:05 am »
I see 4.28 uS in red in the bottom right corner and that looks right to me from the trace seen on screen.
(thinking back to the days when I had a CRO and NO luxury of on-screen measurements)
    • JP-Electronics
« Reply #2 on: November 27, 2014, 09:50:52 am »
Rise(1)=2.900uS
|dX|=2.960uS
What the number in red at the bottom means ? no clue ? From 0% to 100% ?
« Last Edit: November 27, 2014, 09:52:47 am by janengelbrecht »
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: November 27, 2014, 11:43:40 am »
The image I'm seeing doesn't have a red value at bottom RH ??
The T-> 4.280us text indicates the trigger time...?
Is that what you're asking.
See the orange T symbol at the top-left... that's the Trigger marker, and the number at bottom RH is simply that horizontal 'trigger' time position wrt the trace start at 'zero'.
Don't ask a question if you aren't willing to listen to the answer.
    • JP-Electronics
« Reply #4 on: November 27, 2014, 03:28:36 pm »
Well thx for reply...now i get the number in the right corner... still not totally shure if the RIgol meassure rise time from 10% to 90% it writes : Rise(1)=2.900uS and i can see it matches my 10% to 90% meassurement...so ok...lets say it does :)
Offline rollatorwieltje
  • I brick your boards.
    • JP-Electronics
« Reply #6 on: November 27, 2014, 08:25:57 pm »
Thx :)  ^-^ Empty page :P
« Last Edit: November 27, 2014, 08:27:58 pm by janengelbrecht »
Offline jancumps
  • New Low
« Reply #7 on: November 27, 2014, 08:58:04 pm »
It says:
Rise Time: Time that the leading edge of the first pulse in the waveform takes to rise from 10% to 90% of its amplitude.
Offline markce
« Reply #8 on: November 27, 2014, 11:33:23 pm »
Checked this against a Tek scope.
Rigol DS1052E rise-time measurement is 10%-90% time of leading-edge.
Confirmed with real test setup.
I've been quite happy with pulse measurements on the small Rigol.
« Last Edit: November 28, 2014, 10:18:23 pm by markce »
Offline i4004
  • Country: hr
« Reply #9 on: November 28, 2014, 08:56:54 pm »
depends on the signal you're measuring, if it has some jitter then rise time will be more of an aproximation than precise value....you'll see it (auto mode) struggling with finding correct amplitude(s)/ie rise time.
if in your case it's pretty still and non moving much, it should be correct.
