Looks like a barely updated SDS1102. But apart from the memory depth, it does not looks like much of an update. If they just want a newer SDS1102, then it is fine, I guess, but otherwise I don't see why bother.
It even uses the same plastic mold for the back cover as SDS1102. They just rearranged the front panel a bit, and made it worse, IMO.
I use SDS1102 as a main basic scope and it is quite good for what it is. It is silent (no fan at all) and boots instantly. The only thing that is really bad about it is the single trigger. Once it is triggered, re-triggering it is a lot of effort instead of a single button press. Realistically, if they fix just that I would really consider getting that. But I really doubt they did, the software looks pretty much the same.
