Hi, in terms of functionality I really like my recently bought Owon HDS272S a lot - but I came across a very strange issue with its "low battery" detection: The battery indicator changes from "half full" to "red/empty" abruptly at pretty exactly 3.7V battery voltage - and the device switches off when the battery voltage has reached 3.5V.
This lets about half of the energy content of the battery unused - while of course ending operations on battery unfavorably soon.
I checked the capacity and impedance of both 18650 cells - those are fine - their capacity is even somewhat better than advertised.
I also powered the Owon HDS272S from a lab power supply, this reproduced the behaviour with the battery perfectly, so the issue has to be with the detection of what is considered "low battery".
Has anyone else experienced this issue?
I wonder whether I should return my exemplar as faulty, given that half the possible battery life is kind of disappointing.
(It's nice, though, that one can power the device from USB without batteries in it, for stationary use.)
