Some info.
It is much lighter than the other versions of the HDS, and a little smaller in size.
The inside was full of flux, I had to clean it, and it had already been manually repaired by Owon.
The part of the multimeter is very similar to that of the previous Owons.
The only innovation is MIN/MAX/AVG.
It measures RMS well only up to 1-2 kHz.
The update is approx. 3 measurements per second.
The lower bar is updated together with the numbers, that is, it only shows the range.
1 MHz is in the "V" range. From 1V to 500V /Div
The fastest time base is 2.5 us, which can still be comfortably used for a 500kHz signal and it seems stable.
But above it, the signal will be so dense and jumps at the peaks.
In the "V" position, all voltages seem to be in the 1MHz range.
In the "mV" position, the situation is different. "30mV, 100mV, 300mV" /Div.
For 30mV/div already at 15kHz, the 100mVpp sine is only 74mVpp.
For 100mV/Div at ~150kHz
300mV/Div also has a limit of ~150kHz.
Above it, the amplitude of the signal decreases significantly.
You cannot move the trigger to the right or left.
The only way to move the signal laterally is when recording is stopped with the play/pause button or single trigger. with F1 and F2.
There is no signal outside the screen, you can only save as many waves as are visible on the display in each timebase.
You can enlarge the stopped signal by 5 time bases.
It can also trigger on very slow signals. 0.1Hz "Auto button"
I think its display is better than that of similar gadgets.
The above example really cannot be fulfilled by this, at least a 6mV signal must be visible in the 30mV/Div.
It seems that there will be another version, at least the description may indicate that.
in the continuity test, it is highlighted separately that it cannot be adjusted for this version.
However, it is present in the menu, but I cannot change it.
There is also the OWON CMS101 clamp meter, which will slowly be available soon. with some plus feature
