Author Topic: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG  (Read 242167 times)
Offline jeroen94704
Re: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG
« Reply #650 on: June 09, 2023, 05:59:32 pm »
Hi All,
I just purchased the HDS272, so without built-in AWG, and am very happy with the device so far. When I opened it up it looks a lot like it's just an assembly variant of the model with AWG though, since there is a spot for an extra BNC connector. Looking at pictures of the HDS272S internals it looks like the exact same board, except that one has the third BNC connector installed. It wouldn't surprise me if one can simply add that third BNC and install the HDS272S firmware, but I wanted to check if anyone here has taken the plunge and tried this already.
A potential snag is getting the firmware binary. My device is at V8.1.0, and if I understand correctly the major version is tied to a specific revision of the PCB. Unfortunately it looks like Owon do not provide the V8.x binaries on their site, even though other versions (6.1.0, 5.7.1 etc) are available for both the HDS272 and HDS272S. Does anyone know where to get the V8.1.0 firmware for the HDS272S?
Thanks in advance,
Jeroen
Offline orb
« Reply #651 on: June 09, 2023, 06:11:18 pm »
https://www.owon.com.hk/index-1.asp
Look at the bottom of the page ("CONTACT US"), there is an email address.
I came here for a while.
Offline NoMoreMagicSmoke
« Reply #652 on: June 09, 2023, 06:19:45 pm »
Hi All,
Thanks in advance,
Jeroen
Unlikely because the AWG chip is probably also not populated. You can check by looking at display side of the PCB.
Offline jeroen94704
« Reply #653 on: June 09, 2023, 06:22:14 pm »
Ah, that makes sense. I didn't go that far in yet, but you're probably right. Oh well, I guess my next project is going to be building a signal generator  :).
Thanks!
Offline raidersan
« Reply #654 on: June 10, 2023, 11:19:43 am »
Hello all,
I am a complete noob when it comes to oscilloscope but I have done as much leaning as I could and have watched retro computer videos for years, so I thought I would be able to get the basics right at least but I have very quickly found the shallow bottom of my knowledge pool.
I have bought a Owon HD242 as I am currently only interested in low frequency retro computers. My first victim is a C64 running at 1Mhz. Basic signal like clock are fine but as soon as I probe address or data lines on the bus, I get a mess of lines. The scope seems to trigger but I have 10 to 20 competing lines at least on my display. If I stop the capture, it is still all messed up but when I move my cursor left or right, then it seems to sort itself out. I am doing something wrong or is the scope faulty? I am on the V8.1.0 firmware.
Probe and scope on 10x but I have tried 1x as well. Of course DC coupling, I have tried the AUTO button and I have done the probe compensation. But the problem seems to be more in the behaviour of the software than the capture IMO.
Anybody has an idea?
Many thanks!
Offline tunk
  • Country: no
« Reply #655 on: June 10, 2023, 04:09:59 pm »
Not much experience with scopes, but I think normal triggering
is most useful with repeating wave forms (e.g. sine wave, square
wave, PSU ripple). Address and data lines aren't repeating, so
you will see "a mess of lines". You could try to set the trigger
type to single.
Offline Aldo22
« Reply #656 on: June 10, 2023, 04:56:41 pm »
Does it look similar to this video?
https://youtu.be/Uqrel5fQpK4?t=1278
Offline raidersan
« Reply #657 on: June 10, 2023, 10:13:19 pm »
Exactly what it shows at 22:10! The video mentions "persistence" which is the word that came to my mind initially as well, but there is no setting I can find to switch it off. One difference, in the video he takes the probe off the pin and the signal looks fine, mine seems messed up until I scroll left or right
« Reply #658 on: June 10, 2023, 10:53:49 pm »
Go under the horizontal time base menu it's on the second page.
Offline Shonky
« Reply #659 on: June 11, 2023, 03:23:06 am »
My HDS2102S only has "Refresh High/Low", "Hor Center" and "Counter On/Off" on the second page of the horizontal menu. Is Refresh Low what you're referring to - I don't have a suitable signal to test right now.
« Reply #660 on: June 11, 2023, 01:59:34 pm »
Yes try refresh low. That being said, what are you trying to see? A basic scope like the Owon is only heading to tell you if data is going over the wire, nothing about the data itself.
Offline raidersan
« Reply #661 on: June 11, 2023, 03:20:55 pm »
Thanks guys, setting refresh to low works perfectly. I can now use it.
Offline orb
« Reply #662 on: June 12, 2023, 07:23:48 am »
Evil twins (fw: v3.0.0 & v4.1.0). Both have "base" noise.
The following users thanked this post: Markus2801A
Offline jemarro12
« Reply #663 on: July 02, 2023, 09:14:47 pm »
Hello everybody, I made a series of 3 videos of this scope (1 intro, 2 dmm, 3 scope).
Those are my first videos, be kind with me...
I spake Spanish in videos too.
If you want to check I attach a link with part 3 (scope review).
https://youtu.be/z3vBFMeZHes
« Last Edit: July 05, 2023, 02:27:41 pm by jemarro12 »
The following users thanked this post: egonotto, Markus2801A
Offline gdr771
« Reply #664 on: July 19, 2023, 05:37:17 pm »
Anyone know the time/div range for roll mode?  I don't see anything about roll mode in the specs (https://www.owon.com.hk/products_owon_hds200_series_digital_oscilloscope).
Offline rhb
« Reply #665 on: July 20, 2023, 06:47:34 pm »
100 ms/div
Offline orb
« Reply #666 on: July 20, 2023, 07:42:41 pm »
100, 200, 500 ms/div
1, 2, 5, 10, 20, 50, 100, 200, 500, 1000 s/div
Offline kru.czekdb
    • Sędzice 23
« Reply #667 on: July 24, 2023, 08:20:00 am »
Does anyone else have a problem with the speed of the multimeter - especially the squeak? Board v3.2 software V8.1.0
Offline alank2
« Reply #668 on: July 28, 2023, 10:41:49 pm »
I haven't read the 27 page thread yet, but have some questions:
#1 - Is there a way to hack the units such as turning a 272S into a 2202S for example?
#2 - Assuming no to #1, are the 2102S or 2202S units worth the extra money?
#3 - What does everyone think of the AWG, same question, is it also worth the extra money?
#4 - Any problems with these units, downsides, etc?
I've been wanting to mess around with a handheld one and I really like the low price of the 272S @ $185 at Amazon.
Offline tunk
  • Country: no
« Reply #669 on: July 29, 2023, 09:24:22 am »
#1 IIRC different hardware -> no
Offline Shonky
« Reply #670 on: July 29, 2023, 11:40:20 am »
And even then there are different hardware variants within the same model number that run somewhat different versions of firmware.
Offline adam4521
« Reply #671 on: July 29, 2023, 10:45:46 pm »
I've borrowed one of these, HDS242S.
#2 This is a basic, edge triggering oscilloscope. For me, more bandwidth would be diminishing returns for the extra money. If you are doing demanding work, you might be better off putting the money aside towards a more featured bench oscilloscope. But it depends on your project/use case though.
#3 Yes I think the AWG is a high value feature. Limited amplitude range, no modulation. But much less expensive than a standalone device.
#4 The best features are its compactness, convenience and being 'isolated' (the inputs and outputs are not isolated from each other, but the whole thing is floating with respect to the device you are testing when you are on battery power). Downsides are the short memory depth, so you can't zoom in very far on 'bursts' and the somewhat awkward rubber button interface is less convenient than rotating knobs you have on a bench oscilloscope. However, if you are patient and work through it, the compromise is ok.
Offline alank2
« Reply #672 on: July 30, 2023, 12:06:10 am »
Has anyone tested the bandwidth on the 40 MHz model?
Online egonotto
« Reply #673 on: July 30, 2023, 12:50:32 am »
Hello,
in https://www.mikrocontroller.net/topic/542385 at 27.11.2022 16:27, 16:34 and 16:42 Old P shows a few measurements.
Best regards
egonotto
« Last Edit: July 30, 2023, 12:54:06 am by egonotto »
Offline porter
« Reply #674 on: July 31, 2023, 07:16:41 am »
Some of the translations are interesting on that mikrocontroller.net thread.
Ikea wrote:
> the PM3350A
For heaven's sake...
What a towing to balance the oil tubular cucumber around the area
and then look for a socket.
