i'm surprised that my HDS2102S only can do minimum 10mV/div on 1X probe setting (100mV/div on 10X probe) even though the displayed traces are still very clean. why this device dont let us dial down to 5mV/div, 2mV and even down to 1mV/div at 1X probe? i already email to ask for firmware update to enable this.
My guess is that is because of noise pickup and that in turn is because of ineffective front end shielding. The noise would get worse and worse as the input is made more sensitive (5mv, 1mv, 500uv, etc.) and that would look bad because it would look like a very fuzzy line.
For me though, i have delt with this before and it's not the end of the world i got more information from having a fuzzy line than no line at all. If you stick a sensitive scope across a resistor to sense current (not the best method of course but cheap) you get a very fuzzy current waveform but you can still glean a lot of information from it by thinking in terms of the average of the fuzzyness and then you see a wave that is more familiar.
So in the end they may not have been able to deal with the noise pickup as well as some of the upper end scopes.
Personally i prefer a scope that can go down to at least 1mv and so 100mv at 10x would not be something i would like, but if the prices is right and bandwidth ok i might put up with it anyway. Up to this point i have been dealing with a 1MHz DSO scope, a old old 10MHz analog, and a 15MHz DSO PC based, so something at 40MHz or 70MHz would be an improvement for me.
It is entirely possible to upgrade the front end too, with an external amplifier made with a modern op amp. Maybe we could start a group project to design a 10x front end amplifier. That would quickly turn 10mv per into 1mv per div. The op amps these days are very worthy. Maybe power it with a 9v battery or something simple like that. I would not mind using a 9v battery for that it would draw little current anyway. We'd have full control over noise and input protection that way too.
Even perhaps someone did this already and we could use that design.
