Author Topic: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG  (Read 242306 times)
csuhi17 and 3 Guests are viewing this topic.
Offline konnor
  • Country: ru
Re: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG
« Reply #450 on: September 27, 2022, 12:37:11 pm »
The results of a small study.
- The upp file consists of a header and several files.
  For the case with the HDS200 line, there are two files inside
  1)CPU firmware
  2)FPGA firmware.
  No pack.
- Firmware files with same FW version, but different device (242/272/242S/272S) - are identical.
  The only difference is in the model name in the header of the upp file.
  The CPU and FPGA files are the same in all variants.
Known version/model names (in firmware header):
Grouped by matching files in firmware
Version     Device platform name
V1.7.0    HDS272S
V1.7.0zz  HDS242S
V3.3.3    HDS272S_1
V3.3.3    HDS272_1
V3.3.3    HDS242S_1
V3.3.3    HDS242_1
V4.6.1    HDS272S_1
V4.6.1    HDS272_1
V4.6.1     HDS242S_1
V4.6.1    HDS242_1
V4.6.2    HDS272S_1
V5.6.2zz  HDS272S_1
V5.6.3    HDS272S_1
V5.7.1    HDS272S_1
V5.7.1    HDS272_1
V5.7.1    HDS242S_1
V5.7.1    HDS242_1
V6.1.0    HDS272S_1
V6.1.0     HDS272_1
V6.1.0    HDS242S_1
V6.1.0    HDS242_1
V1.4.1    HDS2102S_1
V1.5.1    HDS2102_1
V1.5.1    HDS2102S_1
V2.0.4    HDS2102_LS
V2.0.4    HDS2102S_LS
Different HW platform:
low speed ADC (MXT208)
1)HDS2*2*
2)HDS2*2*_1
High speed ADC:
3)HDS2102*_1    - ADC HMCAD1511
4)HDS2102*_LS    - ADC LS08D1500
It is a pity that there is no firmware from my device on the site.
Only old version (2.0.4)
Used CPU resource:
USART0 - debug console + alternative SCPI (3 pin socket) (115200)
USART1 - DMM Interface (9600)
SPI0 - internal disk nvram
SPI1 - FPGA nvram
ADC - batt monitoring + calibrate procedure
gpio:
PA0 - power key
PA1 - power control (0 - off)
PA4 - SPI0 CS
PB0 - Charger (?)
PB1 - USB detect(?)
PB5-8 - DMM Control
PB12 - SPI1 CS
PC0-2 - Keyboard
PC13-15 - Keyboard
PD3 - DMM Control
PD6 - DMM Control
PE0-1 - Keyboard
The following users thanked this post: eevbstedt, stylon, agaelema, Markus2801A
Offline hobbeeist
« Reply #451 on: September 30, 2022, 05:05:57 am »
konnor,
I don't see the string "HDS" anywhere in the upp file I used to upgrade. Did you perform some sort of decryption first?
Offline konnor
  • Country: ru
« Reply #452 on: September 30, 2022, 11:20:02 am »
Yes, some time ago I took care of writing a simple packer / unpacker for OWON firmware (not only for HDS200). If needed, I can post it. But I'm a little worried that this will increase the number of "bricked" devices. Not everyone has a jtag adapter, and the boot sector is not included in the update.
The following users thanked this post: Mechatrommer, blurpy
Offline rn777
  • Country: ru
« Reply #453 on: September 30, 2022, 06:59:28 pm »
Need. Please, post it.
OWON HDS272s f/w 5.7.1, h/w 3.0, s/n 2152***
The following users thanked this post: tly
Offline konnor
  • Country: ru
« Reply #454 on: September 30, 2022, 07:20:14 pm »
There are two modes of operation - disassemble the firmware into components and assemble the firmware from the components. If everything works fine, then when you perform two operations in sequence, you should get a file that matches the initial file.
The following users thanked this post: rn777, tly
Offline hobbeeist
« Reply #455 on: October 02, 2022, 07:22:29 am »
Were there any undocumented features you came across in your investigation? Maybe some secret API commands, or functions that are present, but not called?
Offline konnor
  • Country: ru
« Reply #456 on: October 02, 2022, 09:49:05 am »
Some undocumented SCPI extension.
!!!DON'T USE command "SECurity"!!!
It removes the protection bits, but I'm not sure that this will not erase the
entire firmware. In this case, the device will be irreversibly corrupted.
Unfortunately, I don't have a 3.0.1 firmware image, and jtag appears to be blocked.
Because of this, I can't do any experiments yet.
I really do not want to roll back to 2.0.4 (which is _possibly_ compatible).
By the way - owners of HDS2102 with firmware 2.0.4 can ask OWON about the possibility of updating to 3.0.1.
main SCPI parser three:
  CH1 = SCPI_AddHook(0, "CH1", 0, 0);
  SCPI_AddHook(CH1, "DISPlay", (int (__fastcall *)(char *))SCPI_CH1_DISPlay_Set, SCPI_CH1_DISPlayGetText);
  SCPI_AddHook(CH1, "COUPling", (int (__fastcall *)(char *))SCPI_CH1_SetupCoupling, SCPI_CH1_GetCoupling);
  SCPI_AddHook(CH1, "BANDwidth", (int (__fastcall *)(char *))SCPI_CH1_SetupBandwidth, SCPI_CH1_GetBandwodthText);
  SCPI_AddHook(CH1, "PROBe", (int (__fastcall *)(char *))SCPI_SetupProbe, SCPI_CH1_GetProbeText);
  SCPI_AddHook(CH1, "SCALe", (int (__fastcall *)(char *))SCPI_CH1_SetupVScale, SCPI_CH1_GetScaleText);
  SCPI_AddHook(CH1, "OFFSet", (int (__fastcall *)(char *))SCPI_SetOffset_1, SCPI_CH1_GetOffset);
  CH2 = SCPI_AddHook(0, "CH2", 0, 0);
  SCPI_AddHook(CH2, "DISPlay", (int (__fastcall *)(char *))SCPI_CH2_DisplaySet, SCPI_CH2_DisplayGet);
  SCPI_AddHook(CH2, "COUPling", (int (__fastcall *)(char *))SCPI_CH2_CouplingSet, SCPI_CH2_CouplingGet);
  SCPI_AddHook(CH2, "BANDwidth", (int (__fastcall *)(char *))SCPI_CH2_BandWidthSet, SCPI_CH2_BandWidthGet);
  SCPI_AddHook(CH2, "PROBe", (int (__fastcall *)(char *))SCPI_CH2_ProbeDividerSet, SCPI_CH2_ProbeDividerGet);
  SCPI_AddHook(CH2, "SCALe", (int (__fastcall *)(char *))SCPI_CH2_SetupVScale, SCPI_SCPI_CH2_VScaleGet);
  SCPI_AddHook(CH2, "OFFSet", (int (__fastcall *)(char *))SCPI_CH2_OffsetSet, SCPI_CH2_OffsetGet);
  Hor = SCPI_AddHook(0, "HORizontal", 0, 0);
  SCPI_AddHook(Hor, "SCALe", (int (__fastcall *)(char *))SCPI_HorScaleSet, SCPI_HorScaleGet);
  SCPI_AddHook(Hor, "OFFSet", (int (__fastcall *)(char *))SCPI_HorOffsetSet, SCPI_GetHorOffset);
  ACQuire = SCPI_AddHook(0, "ACQuire", 0, 0);
  SCPI_AddHook(ACQuire, "MODe", (int (__fastcall *)(char *))SCPI_ChangePeakMode, SCPI_GetPeakModeStr);
  SCPI_AddHook(ACQuire, "DEPMem", (int (__fastcall *)(char *))SCPI_ChangeDepMem, SCPI_GetDepMemStr);
  Data = SCPI_AddHook(0, "DATa", 0, 0);
  Data_Wawe = SCPI_AddHook(Data, "WAVe", 0, 0);
  Data_Wawe_Screen = SCPI_AddHook(Data_Wawe, "SCReen", 0, SCPI_Data_Wawe_Screen_CH1);
  SCPI_AddHook(Data_Wawe_Screen, "CH1", 0, SCPI_Data_Wawe_Screen_CH1);
  SCPI_AddHook(Data_Wawe_Screen, "CH2", 0, SCPI_Data_Wawe_Screen_CH2);
  SCPI_AddHook(Data_Wawe_Screen, "HEAD", 0, SCPI_Data_Wave_Screen_Head);
  Trigger = SCPI_AddHook(0, "TRIGger", 0, 0);
  SCPI_AddHook(Trigger, "STATus", 0, SCPI_GetTriggerStatusText);
  Trigger_single = SCPI_AddHook(Trigger, "SINGle", 0, 0);
  Trigger_single_edge = SCPI_AddHook(
                          Trigger_single,
                          "EDGe",
                          (int (__fastcall *)(char *))SCPI_SetEdgeMode,
                          SCPI_GetEdgeText);
  SCPI_AddHook(Trigger_single_edge, "LEVel", (int (__fastcall *)(char *))SCPI_SetTriggLevel, SCPI_GetTriggLevel);
  SCPI_AddHook(Trigger_single_edge, "SOURce", (int (__fastcall *)(char *))SCPI_SetTriggSourcfe, SCPI_GetTriggSourceText);
  SCPI_AddHook(Trigger_single, "SOURce", (int (__fastcall *)(char *))SCPI_SetTriggSourcfe, SCPI_GetTriggSourceText);
  SCPI_AddHook(Trigger_single, "COUPling", (int (__fastcall *)(char *))SCPI_Setup_AC_DC, SCPI_GetCoupling);
  SCPI_AddHook(Trigger_single, "SWEep", (int (__fastcall *)(char *))SCPI_SetSWeepMode, SCPI_GetTriggerModeStr);
  MEASuremen = SCPI_AddHook(0, "MEASuremen", 0, 0);
  SCPI_AddHook(
    MEASuremen,
    "DISPlay",
    (int (__fastcall *)(char *))SCPI_MEASuremen_Display_Set,
    SCPI_MEASuremen_Display_Get);
  MEASuremen_CH1 = SCPI_AddHook(MEASuremen, "CH1", 0, 0);
  SCPI_AddHook(MEASuremen_CH1, "MAX", 0, SCPI_MEASuremen_CH1_MaxGet);
  SCPI_AddHook(MEASuremen_CH1, "MIN", 0, SCPI_MEASuremen_CH1_MinGet);
  SCPI_AddHook(MEASuremen_CH1, "PKPK", 0, SCPI_MEASuremen_CH1_PkPkGet);
  SCPI_AddHook(MEASuremen_CH1, "VAMP", 0, SCPI_MEASuremen_CH1_VampGet);
  SCPI_AddHook(MEASuremen_CH1, "AVERage", 0, SCPI_MEASuremen_CH1_AverageGet);
  SCPI_AddHook(MEASuremen_CH1, "PERiod", 0, SCPI_MEASuremen_CH1_PeriodeGet);
  SCPI_AddHook(MEASuremen_CH1, "FREQuency", 0, SCPI_MEASuremen_CH1_Freq);
  SCPI_AddHook(MEASuremen_CH1, "RTime", 0, SCPI_MEASuremen_CH1_RTime);
  SCPI_AddHook(MEASuremen_CH1, "FTime", 0, SCPI_MEASuremen_CH1_FTime);
  SCPI_AddHook(MEASuremen_CH1, "PWIDth", 0, SCPI_MEASuremen_CH1_PWidth);
  SCPI_AddHook(MEASuremen_CH1, "NWIDth", 0, SCPI_MEASuremen_CH1_NWidth);
  SCPI_AddHook(MEASuremen_CH1, "SQUAresum", 0, SCPI_MEASuremen_CH1_SquareSum);
  MEASuremen_CH2 = SCPI_AddHook(MEASuremen, "CH2", 0, 0);
  SCPI_AddHook(MEASuremen_CH2, "MAX", 0, SCPI_MEASuremen_CH2_MaxGet);
  SCPI_AddHook(MEASuremen_CH2, "MIN", 0, SCPI_MEASuremen_CH2_MinGet);
  SCPI_AddHook(MEASuremen_CH2, "PKPK", 0, SCPI_MEASuremen_CH2_PkPkGet);
  SCPI_AddHook(MEASuremen_CH2, "VAMP", 0, SCPI_MEASuremen_CH2_VampGet);
  SCPI_AddHook(MEASuremen_CH2, "AVERage", 0, SCPI_MEASuremen_CH2_AverageGet);
  SCPI_AddHook(MEASuremen_CH2, "PERiod", 0, SCPI_MEASuremen_CH2_PeriodeGet);
  SCPI_AddHook(MEASuremen_CH2, "FREQuency", 0, SCPI_MEASuremen_CH2_FreqGet);
  SCPI_AddHook(MEASuremen_CH2, "RTime", 0, SCPI_MEASuremen_CH2_RTimeGet);
  SCPI_AddHook(MEASuremen_CH2, "FTime", 0, SCPI_MEASuremen_CH2_FTimeGet);
  SCPI_AddHook(MEASuremen_CH2, "PWIDth", 0, SCPI_MEASuremen_CH2_pWidthGet);
  SCPI_AddHook(MEASuremen_CH2, "NWIDth", 0, SCPI_MEASuremen_CH2_NWidthGet);
  SCPI_AddHook(MEASuremen_CH2, "SQUAresum", 0, SCPI_MEASuremen_CH2_SquareSumGet);
  Function = SCPI_AddHook(0, "FUNCtion", (int (__fastcall *)(char *))SCPI_SetGeneratorMode, SCPI_GetGeneratorMode);
  SCPI_AddHook(Function, "FREQuency", (int (__fastcall *)(char *))SCPIFun_Freq_Set, SCPI_Fun_Freq_Get);
  SCPI_AddHook(Function, "PERiod", (int (__fastcall *)(char *))SCPI_Fun_Period_Set, SCPI_Fun_Period_Get);
  SCPI_AddHook(Function, "AMPLitude", (int (__fastcall *)(char *))SCPI_Fun_Ampl_Set, SCPI_Fun_Ampl_Get);
  SCPI_AddHook(Function, "OFFSet", (int (__fastcall *)(char *))SCPI_Fun_Offset_SEt, SCPI_Fun_Offset_Get);
  SCPI_AddHook(Function, "HIGHt", (int (__fastcall *)(char *))SCPI_Fun_Hightt_SEt, SCPI_Fun_Hightt_GEt);
  SCPI_AddHook(Function, "LOW", (int (__fastcall *)(char *))SCPI_Fun_Low_SEt, SCPI_Fun_Low_GEt);
  SCPI_AddHook(Function, "SYMMetry", (int (__fastcall *)(char *))SCPI_Fun_Symmetry_SEt, SCPI_Fun_Symmetry_GEt);
  SCPI_AddHook(Function, "WIDTh", (int (__fastcall *)(char *))SCPI_Fun_Width_SEt, SCPI_Fun_Width_GEt);
  SCPI_AddHook(Function, "DTYCycle", (int (__fastcall *)(char *))SCPI_Fun_Duty_SEt, SCPI_Fun_Duty_GEt);
  SCPI_AddHook(Function, "RISing", (int (__fastcall *)(char *))SCPI_Fun_Rising_SEt, SCPI_Func_Rising_Get);
  SCPI_AddHook(Function, "FALing", (int (__fastcall *)(char *))SCPI_Fun_Faling_SEt, SCPI_Fun_Faling_GEt);
  SCPI_AddHook(Function, "LOAD", (int (__fastcall *)(char *))SCPI_Fun_LoadOnOff_SEt, SCPI_Fun_LoadOnOff_GEt);
  SCPI_AddHook(0, "CHANnel", (int (__fastcall *)(char *))SCPI_ArbChannelSet, SCPI_ChannelGet);
  SCPI_AddHook(0, "MODel", 0, SCPI_Get_String_Model);
  SCPI_AddHook(0, "SERial", (int (__fastcall *)(char *))SCPI_Set_String_Serial, 0);
  SCPI_AddHook(0, "AUToset", (int (__fastcall *)(char *))SCPI_Autoset, 0);
  SCPI_AddHook(0, "Selfcorrec", (int (__fastcall *)(char *))SCPI_Selfcorrec_Set, 0);
  SCPI_AddHook(0, "SECurity", (int (__fastcall *)(char *))SPCI_SecuritySet, 0);
  DMM = SCPI_AddHook(0, "DMM", (int (__fastcall *)(char *))SCPI_DMM_Config_Set, SCPI_DMM_Get_String);
  DMM_Configure = SCPI_AddHook(DMM, "CONFigure", (int (__fastcall *)(char *))SCPI_DMM_Config_Set, SCPI_DMM_Get_String);
  SCPI_AddHook(DMM_Configure, "VOLTage", (int (__fastcall *)(char *))SCPI_DMMConfVoltSet, SCPI_DMM_Get_String_Voltage);
  SCPI_AddHook(DMM_Configure, "CURRent", (int (__fastcall *)(char *))SCPI_DMMConfCurrSet, SCPI_DMM_Get_String_Current);
  SCPI_AddHook(DMM, "REL", (int (__fastcall *)(char *))SCPI_DMM_Rel_Set, SCPI_DMM_Rel_Get);
  SCPI_AddHook(DMM, "RANGE", (int (__fastcall *)(char *))SCPI_DMM_Range_Set, SCPI_DMM_Range_Get);
  SCPI_AddHook(DMM, "AUTO", (int (__fastcall *)(char *))SCPI_DMM_AutoSet, SCPI_DMM_AutoGet);
  SCPI_AddHook(DMM, "MEAS", 0, SCPI_DMM_MeasGet);
  SCPI_AddHook(0, "VIDEO", SCPI_SetVideo, 0);
  SCPI_AddHook(0, "VOLFULL", SCPI_VOLFULL, 0);
Separate command:
STARTDEBUGTXT - HW model info
COLOR - lcd palette setup
SOFTWARERESET - reset
Special key seq:
Sys,sys,up,up,down,down,left,left,right,right - switch key "system" to enter specail menu
in Measure menu:
f3,f3,f4,f4,f3,f4,f3f4 - run some VERY long operations (7 step), with the output of not quite clear results. The operations are really long, and the device does not respond to the buttons at this time.
I can't say what the consequences will be (probably nothing worse than having to reset to default and recalibrate), but BETTER DO NOT EXPERIMENT.
The following users thanked this post: Mechatrommer, egonotto, rn777, hobbeeist
Offline JogaBonito5
« Reply #457 on: October 02, 2022, 10:05:00 am »
Hello guys, I just bought the OWON HDS242!
I attached some pictures regarding software information and PCB revision.
I just have one minor problem: I have no batteries right now so the only way to turn it on is via USB cable. The problem is that when i plug it in, the power button starts flashing without stop. The oscilloscope works without any issues but this red flashing light is so annoying!
Here's a video that shows the problem: https://gofile.io/d/FuRrn5.
Is this a feature? Because i can't find any reference about it. Maybe it's because there are no batteries in?
Small update to my problem:
I wrote to OWON directly and they say that yes, if no batteries are installed, the power button will flash.
That's kind of an annoying feature lol.
Offline NoMoreMagicSmoke
« Reply #458 on: October 02, 2022, 02:41:10 pm »
Why don't you have batteries?
Offline JogaBonito5
« Reply #459 on: October 02, 2022, 03:40:56 pm »
Because I thought it would came with batteries lol
I bought it from pollin.de but probably didn't pay too much attention to the description
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #460 on: October 02, 2022, 05:59:46 pm »
blinking button to warn missing batteries is a preferable feature imho. to warn us to get batteries asap. operating without batteries could overload charging circuit, or not recommended because of various reasons.
« Reply #461 on: October 02, 2022, 06:24:25 pm »
Weird. Must be something with that vendor.
Offline JogaBonito5
« Reply #462 on: October 02, 2022, 07:41:07 pm »
I see the point, yeah that's right. But I hoped for a direct supply via cable, like bypassing the overload circuit or something like that so I wouldn't have to rely always on batteries   :D
Offline konnor
  • Country: ru
« Reply #463 on: October 20, 2022, 06:22:26 pm »
ADC area HDS2102S vs HDS2202S:
The following users thanked this post: TheBay, Markus2801A
Offline eti
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« Reply #464 on: October 23, 2022, 02:11:10 am »
To save a thread trawl, would someone tell me what the latest HDS272S firmware is (V3 H/W if I recall) and what it has that deems an upgrade worthwhile? Charrrrz!
Offline gtube
« Reply #465 on: October 28, 2022, 09:30:52 pm »
The new V3 version use Chinese made 1Ghz 8bit ADC. Here is the link:
http://linsimicro.com/Products/info.aspx?itemid=5
Offline eti
« Reply #466 on: October 28, 2022, 10:26:49 pm »
Ah, no, what I meant was, what is the latest firmware, and what is in it to make it worth me upgrading? Thanks!
Offline topconchen
  • Country: hk
« Reply #467 on: November 02, 2022, 09:35:06 am »
 The latest firmware is V8.0.1,it can't be downloaded.
Online tunk
  • Country: no
« Reply #468 on: November 02, 2022, 12:23:48 pm »
Any chance of opening it, i.e. to see if the hardware is the same?
Offline eti
« Reply #469 on: November 03, 2022, 05:13:54 am »
You can credit $5 to my paypal i'll do the homework for you...
It’s useful to quote people to whom you’re responding, otherwise we have an ambiguous reply floating in space with no recipient known.
Offline eti
« Reply #470 on: November 03, 2022, 05:39:34 am »
Yes it is meant as general purpose statement. If quoting name, there is risk of backfire ;D so better not mention it ;) whoever in need will know who the statement is for. Cheers.
Ah, righty Ho 😃
Offline jomaroliv
« Reply #471 on: November 14, 2022, 07:07:37 pm »
Just got mine with FW 8.01 (HDS242). Did not (yet) open to check board version.
Offline jomaroliv
« Reply #472 on: November 15, 2022, 05:16:25 pm »
Ok, só MB revision is 3.02 from end of July 22 FW 8.01
The following users thanked this post: tly, orb
Offline tly
« Reply #473 on: November 16, 2022, 01:54:37 pm »
(just for info:) The batteries can be changed or are glued ?
Offline wb0gaz
« Reply #474 on: November 16, 2022, 02:04:15 pm »
Followed the url (from gtube a few postings back) for linsimicro.com's ADC - didn't see anything that looked like a datasheet link, but the few specs (lower on the page) indicate 7-bit ADC (the headline on the page appears to be 8-bit.)
