Author Topic: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG  (Read 242342 times)
Offline hobbeeist
Re: OWON HDS 200 Handheld Oscilloscope w/ builtin DMM/AWG
« Reply #375 on: March 12, 2022, 04:41:08 pm »
Kerry Wong on the 2 ns bug
https://youtu.be/W5jeG-9RZGU
The following users thanked this post: agmbass
Offline miegapele
  • Country: lt
« Reply #376 on: April 08, 2022, 07:41:56 pm »
Hello,
Does anybody know if SCPI commands support multimeter functions? Manual is silent about this.
Offline steelz75
« Reply #377 on: April 10, 2022, 01:57:37 pm »
Nice to meet you.
We have received the HDS272S V.5.7.1 firmware from OWON and will provide it.
It is compressed with zip.
Have a good HDS200 life!
My Device : HDS272S
Serial : 2148***
Hardware ver. : Unknown
Old Firmware ver. : V.5.3.0
I've a HDS242S with V.5.3.0 firmware! Can I use this update for my OSC?
Owon HDS242s - F/W 5.7.1 - Rev. 3.0 - S/N 2148***
The following users thanked this post: v11
Offline steelz75
« Reply #378 on: April 11, 2022, 02:18:11 pm »
Nobody? Really? Come on guys, give me some advice :)
Offline hobbeeist
« Reply #379 on: April 11, 2022, 04:29:06 pm »
I believe if you read earlier in this thread, you'll see a post where somebody tried loading 272 software onto a 242 meter and bricked it. I'd advise contacting Owon directly.
Offline hobbeeist
« Reply #380 on: April 11, 2022, 04:32:25 pm »
Hello,
Good question! The SCPI doc has commands for the Osc and AWG modes, but not multimeter. I guess you could try running some of the typical multimeter commands and see if you get results back? Shouldn't hurt anything to send the request if it's not supported.
Offline steelz75
« Reply #381 on: April 11, 2022, 05:03:54 pm »
I had seen the discussion but I didn't find it anymore ... thanks for the advice  :-+
Online BILLPOD
« Reply #382 on: April 14, 2022, 07:50:53 pm »
Good Morning, My problem is not the software/firmware inside the scope, but the computer interface software that I downloaded from the Owon site.   The Zip file won't unzip.  I'm using a Windows 10 computer.   If anyone's had this issue I would appreciate the solution to this problem.  Thanks in advance. :-/O
    UPDATE: discovered the download I get from the first Owon site was 'blank'....nothing in it....DUHHHH.  I went to their
'Official' download site and got a good one.   So now I have an o-scope screen, but can't get a waveform on it.   More experimenting, I guess.
« Last Edit: April 15, 2022, 07:53:03 pm by BILLPOD »
Offline ve7vie
« Reply #383 on: April 19, 2022, 06:54:15 pm »
That's funny because I just ordered a 272S because I can't get my old Hantek DSO and AWG to work because of unfixable(?) driver certification issues. They used to work on my Win8.1 machine. Anyway, never again Hantek! I also want to replace my TPI Scopemeter 440.  And I have an HP 1740 (the one that Dave slaved over). FFT would be nice, though.  I paid $240Cdn at Banggood.
Offline gnuarm
  • Country: pr
« Reply #384 on: April 23, 2022, 04:03:17 pm »
I believe that is the mantra of Hantek owners around the world.  "Never Again Hantek!"  or NAH for short.  NAH!
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
Offline rad400
« Reply #385 on: May 01, 2022, 03:12:15 pm »
I recently picked up a HDS 242 (S#2129XXX, Board 3-21-21 V2.0, Firmware V3.2.1) and upgraded the firmware to V3.3.3.  Are there any differences in the performance/accuracy between the different versions of the board?
Offline rad400
« Reply #386 on: May 01, 2022, 10:09:19 pm »
Having problems with Owon HDS242 scope portion.  I inputed a pure 12v RMS sine wave and got readings on the scope of 34Vpp and a mean reading of 67mv.  The 67mv is the problem.  If I did my math correctly, with a meter input of 12Vrms, the scope should be reading around 10.8Vav, but it only reads 67mv.
I have updated the firmware to the latest for my meter of V3.3.3.
Anyone else having this issue?
Thanks
Offline tly
« Reply #387 on: May 02, 2022, 10:05:08 pm »
The mean value of a sine wave is 0; but due to sampling it will never be exactly 0.
Do this test: set a sine signal with 1Vpp + 1V offset.
The mean value displayed should be around the offset value 1V +/- something.
Edit:
Use Peak-2-Peak measurement and convert the measured value to RMS  ;)
« Last Edit: May 02, 2022, 10:26:44 pm by tly »
Offline TheBay
  • Country: wales
« Reply #388 on: May 12, 2022, 09:52:22 am »
I dug this out the other day as I needed to use a handheld scope for something.
Did the CH2 issue ever get resolved on any firmware versions?
If I ever use Auto on mine it will always default to CH2 for controls even though there is nothing connected to CH2, makes it a real PITA to adjust the timebase for CH1 as I have to keep manually selecting CH1. Or I get the annoying message "Channel 2 is Off"
Mine is:
PCB V2.20
Firmware: V4.2.0
Offline Flopdoodley
« Reply #389 on: May 12, 2022, 01:55:13 pm »
Mine is:
PCB V2.20
Firmware: V4.2.0
From all that I've read to this point, there hasn't been a fix for a firmware version that would run on the V2.20 PCB. It has supposedly been fixed as some point for the firmware for later board models. I also understand you could brick the unit if you try to load firmware not made for that board version.
The workaround that I used was to simply hit the AUTO button a second time to toggle the "focus" back to channel-1 (see exception below).
Note that the scope mode has four different display modes (for lack of a better way to put it), and each of those modes will dictate what the blue arrow keys and the "F" keys do.
They are: CH1/2, HOR, Trig, Measure/Range. Each of these modes will highlight their respective function on the screen.
I found that the toggle to CH2 when hitting the AUTO button ONLY happens when the screen indicates that it's in the CH1/2 mode. In all other modes, it works as it should.
Looking at the screen highlights prior to pressing the AUTO button makes it a little less frustrating because you'll know what to expect and whether to hit the AUTO button a second time.
The following users thanked this post: TheBay
Offline fuho
  • Country: cz
« Reply #390 on: May 29, 2022, 03:46:43 pm »
Hello everyone,
I'd like to update the firmware on my OWON HDS272S HW v2.0 FW v3.1.0 serial number 2124xxx. I "think" it should be safe to update to fw v3.3.3 that @tly uploaded, but I'd feel a lot better if anyone who has done so could confirm it worked for them  :phew:
While reading this thread and trying to figure out what is the right firmware for my board revision I compiled all the info I found in a document I am sharing below, I have also collected all the uploaded firmware files and images of hardware revisions.
Unfortunately the attachment upload limits don't allow me to upload the whole packed folder here (not even just all the compressed fw files) so I am sharing it on Google Drive here https://drive.google.com/drive/folders/1lULgGCX0rwCR3fdHBU8-bwArSPSJaWcp?usp=sharing and here is a GitHub gist of the Info Doc https://gist.github.com/fuho/967396859a4f82346095c6abc941a328.
Here is a repository where I intend to store everything https://github.com/fuho/owon_hds200
I'd like to ask anyone who has received firmware from OWON to post it here with details like board revision, board date, fw updating from, the first 4 digits of SN or any info that could help anyone else in figuring out how to upgrade without bricking their device really. Feel free to DM me if you prefer. I'll add it to the archive and update this post.
Right now for example we only have one FW for board revision 2.0 and none for 2.1 or 2.2. Thanks a lot if you decide to help  :-+
# HDS200 Info Doc v2022-06-23.01
## Firmware
[!OWON FW DOWNLOAD CENTER FOR HDS200]([url]https://www.owon.com.hk/download.asp?category=Digital%20Oscilloscope&series=HDS200%20Series&model=&SortTag=Latest%20Firmware[/url])
### FW v5.7.1
- user:            GSR1600
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4030375/#msg4030375[/url]
- model:           HDS272S
- hw_version:      3.0
- original fw:     5.3.0
- serial:          2148xxx
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1424170[/url]
- MD5:             6DDE63D0EFFCA1B0C4E647D077DBA560
- SHA-1:           9D3922FAD636A00D0A9C866DF32AFF31AD02FDDA
### FW v5.6.3
- user:            rn777
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4013077/#msg4013077[/url]
- model:           HDS272S
- hw_version:      3.0
- serial:          2152xxx
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1416373[/url]
- MD5:             02FF935625FD1729A1B8CE0B97DFAAF4
- SHA-1:           8E92F62166E19225EC3F67F65FD92DE4D6308E78
### FW v5.6.3
- user:            eti
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4012864/#msg4012864[/url]
- model:           HDS272S
- hw_version:      3.0
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1416196[/url]
- MD5:             D05A5D23E36E089A6EA952888D019C1B
- SHA-1:           F773BB86256D771494D624813D1C2B79F2A9B980
### FW v5.6.2
- user:            optotester
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg3973145/#msg3973145[/url]
- model:           HDS272S
- hw_version:      3.0
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1394687[/url]
- MD5:             587BE31898848BA7E102EA7C8773A116
- SHA-1:           5130E27FFE62733214DA89225DCFEA7506783D4F
### FW v4.6.2
- user:            wenesga
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4211791/#msg4211791[/url]
- model:           HDS272S
- hw_version:      2.1
- original fw:
- serial:          2146xxx
- download:        [url]https://app.box.com/s/h6vcyczfnft1hih4z47wgo76lu6a053p[/url]
- MD5:             75CF54FB80673E3AEDFE30C93E2E8E09
- SHA-1:           D91344A74BB6D26851AAF9D6FE5B7F6E58B15711
### FW v3.3.3
- user:            tly
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4015513/#msg4015513[/url]
- model:           HDS272S
- hw_version:      2.0
- original fw:     3.2.0
- serial:          2128xxx
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1417543[/url]
- MD5:             4265D84170607FC7827600E9D35D7319
- SHA-1:           B79C51348F1630828DA1D61A36E247B82CA6F452
### FW v1.5.1
- user:            miegapele
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4215118/#msg4215118[/url]
- model:           HDS2102S
- hw_version:      1.0
- serial:          xxxxxxx
- download:        [url]https://www.dropbox.com/s/tkjh575usm05h75/OWON_HDS2102Sv1.5.1.zip?dl=0[/url]
- MD5:             6BC6C317449C66B853698BA14689A18A
- SHA-1:           6C7BC70C006B25AD4965AB1AFB7A1BFA875351BF
### FW v1.4.1
- user:            gtube
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg4027384/#msg4027384[/url]
- model:           HDS2102S
- hw_version:      1.0
- serial:          2152008
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1423126[/url]
- MD5:             40C68BBB4769E3766AAC9F21574547D1
- SHA-1:           2A0F554655BC2A7546DEDD18DE479B6747F3A3B5
### FW v1.7.0
- user:            blurpy
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg3639409/#msg3639409[/url]
- model:           HDS272S
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1250065[/url]
### FW v1.7.0
- user:            julius.gl
- post:            [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg3624563/#msg3624563[/url]
- model:           HDS242S
- original fw:     1.2.0
- serial:          2047xxx
- latest fw:       1.7.0
- download:        [url]https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/?action=dlattach;attach=1243775[/url]
- MD5:             764A75B3580B9BECD3CA5F977B0144FB
- SHA-1:           72E5F744DC524B1B6A92AC9690DC31C055A10B47
## Hardware
At some point flash chip changed from from "Gigadevice" to "Macronix".  The Gigadevice has a type of OTP SecureRom that
is read-only with a hard coded checksum. Those are apparently "NOT upgradable".
#### HDS2102x_main_v1.0
- board date: 2021-09-16
- models: HDS2102S
- firmware: v1.3.3, v1.5.0, v1.5.1
- serials: 2152xxx,
#### HW 3.1
- HDS200_MAIN_V3.1
- board date: 2021-12-28
- firmware: v5.7.1,
- models: HDS242S
- devices:
  - HDS272S (2207xxx - HarleyYan;v5.7.1)
- serials: 2207xxx
#### HW 3.0.1
- HDS200_MAIN_V3.0.1
- board date: 2021-11-20
- firmware:
- models: HDS242
- devices:
  - (2204494 - KyleK29)
- serials: 2204494
#### HW 3.0
- HDS200_MAIN_V3.0
- board date: 2021-09-27
- firmware: v5.1.1, v5.3.0, v5.4.0, v5.6.3, v5.7.1,
- models: HDS2102S
- devices:
  - HDS272S (xxxxxxx - BetterAndBetter;v5.3.0)
  - HDS272 (214xxxx - idolclub;v5.1.1)
  - HDS272S (2149xxx - sequoia;v5.4.0)
  - HDS272s (2149xxx - eti;v5.4.0)
  - HDS272s (2152xxx - rn777;v5.6.3;v5.7.1)
  - HDS272 (2152092 - skander36;v5.4.0;v5.7.1)
  - HDS272S (2148xxx - oldo439)
- serials: 2148xxx, 2149xxx, 2152xxx,
#### HW 2.2
- board date: 2021-09-09
- models: HDS242S
- firmware: v4.2.0, v4.6.1
- devices:
  - HDS272S (xxxxxxx - TheBay;v4.2.0)
  - HDS272S (2319xxx - hacs;v4.6.1)
- serials: 2319xxx,
#### HW 2.1
- HDS200_MAIN_V2.1
- models: HDS242S
- firmware: v3.3.0, v4.2.0, v4.6.1
- devices:
  - HDS2x2x (2130xxx - Sobakin76;v4.1.0)
  - HDS2x2x (2131xxx - Voltlog)
  - HDS272S (2131xxx - Flash2Light;v3.3.0)
  - HDS272S (2131xxx - TheHWCave)
  - HDS272S (2146xxx - wenesga;v4.6.2)
  - HDS272S (2141xxx - NathanFulton;v4.6.2)
- serials: 2319xxx,
#### HW 2.0
- HDS200_MAIN_V2.0
- board date: 2021-03-24
- models: HDS272S
- firmware: v3.0.0, v3.1.0, v3.2.0, v3.3.3
- max firmware: v3.3.3
- Used for serial numbers 2118xxx -> 2129xxx
- devices:
  - HDS272S (xxxxxxx - sijmen;v3.1.0)
  - HDS272S (2124274 - fuho;v3.1.0)
  - HDS242S (xxxxxxx - sotos;v3.0.0)
  - HDS242S (xxxxxxx - nitromethane;v3.0.0)
  - HDS272S (2121xxx - learnelectronics)
  - HDS2x2x (2124xxx - exalab;v3.1.0)
  - HDS272S (2128xxx - giovannirat;v3.2.0)
  - HDS272S (2128xxx - dagobird;v3.2.0)
  - HDS272S (2128xxx - saresigi;v3.2.0)
  - HDS2x2x (2129xxx - papabol_24;v3.2.0)
  - HDS272S (2129xxx - forceman;v3.3.0)
- sn 2124274 has gigadevice flash
#### HW 1.0
- HDS200_MAIN_V1.0
- board date: 2020-09-25
- models: HDS272, HDS272S
- firmware: v1.2, v1.7
- max firmware: v1.7
- devices:
  - HDS272 (2047221 - TrendX)
  - HDS272S (2047xxx - janiorib)
  - HDS272S (2047xxx - julius.gl;v1.2.0;v1.7.0)
- serials: 2047221,
### Unknown Hardware Revisions
HDS272S FW2.01 (RHB)
« Last Edit: June 23, 2022, 08:29:09 am by fuho »
The following users thanked this post: Markus2801A, sulzer, Flopdoodley, saresigi, tly
Offline tly
« Reply #391 on: May 31, 2022, 09:20:34 am »
@ExaLab posted same question.
Send him a PM and ask if he solved or not.
and some info that I noted:
janiorib
HDS272s V1.0    2047xxx
Trendx
HDS272 V1.0 2047xxx
julius.gl
HDS242S FW1.2.0 2047xxx max 1.7.0
RHB
HDS272S FW2.01
sijmen
HD272S FW3.10
sotos
HDS242S with version v3.0.0
nitromethane
HDS242S V2.0 (2021-03-24) main PCB and V3.0.0 firmware
HDS272S v2.0-2021-03-24 2118xxx
learnelectronics (youtube review)
HDS272S v2.0-2021-03-24 2121xxx
Exalab
My unit is SN. 2124xxx, Ver. fw-V3.1.0
giovannirat
HDS272S 2128xxx, firmware release 3.2.0
dagobird
HDS272S here with Serial 2128xxx and Firmware 3.2.0
saresigi
Software version: 3.2.0
Ser. Nr.: 2128xxx
Mainboard date: 2021-03-24
Mainboard Version: V2.0
papabol_24
2129xxx serial number FW 3.2.0 Version 2.0 Main board
forceman
HDS272S, FW V3.3.0, PCB: HDS200-MAIN-V2.1
Sobakin76
SN is 2130xxx HDS200-MAIN-V2.1 V4.1.0
Voltlog (youtube review)
2131xxx mb V2.1
Flash2light
HDS272S V3.3.0 sn: 2131xxx
TheHWCave
HDS272S mb V2.1 sn: 2131xxx
TheBay
HDS272S yesterday. Firmware version is: V4.2.0 / MB V2.20 (2021-09-09)
BetterAndBetter
HDS272S  V5.3.0
idolclub
HDS272  214xxxx HDS200 PCB MAIN V3.0 (2021-09-27) firmware v5.1.1.
sequoia
HDS272S yesterday (from Banggood), this has firmware v5.4.0 but same PCB version it seems.
Serial is in 2149xxx range.
eti
My serial begins “2149” hardware/board V3.0.
rn777
HDS272s f/w 5.6.3, h/w 3.0, s/n 2152***
« Last Edit: May 31, 2022, 09:42:25 am by tly »
The following users thanked this post: fuho
Offline ExaLab
« Reply #392 on: May 31, 2022, 01:40:02 pm »
Hello everyone,
I updated to v 3.3.3 my unit (FW 3.1.0, sn:2124xxx) without any problem!
I got this FW directly from OWON (after many unsuccessful preliminary requests...).
So: upgrade without worrying!
Offline wenesga
  • Country: br
« Reply #393 on: June 02, 2022, 06:25:18 pm »
I have this version
Update Osciloscópio
Model: HDS272S
SN: 2146xxx
Version: 4.6.2
MAIN V2.1
« Last Edit: June 02, 2022, 07:14:57 pm by wenesga »
The following users thanked this post: fuho, NathanFulton
Offline wenesga
  • Country: br
« Reply #394 on: June 02, 2022, 08:57:34 pm »
Anyone tried to hack it from 40mhz to 70?
No need to BW hack, my HDS242 has resulting rise time not more than 5ns (include generator on SN74HC14 with 5-outs-in-parallel has about 2-3ns) which is 70MHz+ BW, just use proper probes.
So if I use a 100mhz probe on an HDS272S (70mhz), will I be able to use it as an HDS2102S (100mhz)?
Offline tautech
« Reply #395 on: June 02, 2022, 08:59:57 pm »
No, BW is determined by the input stages of the scope not the probes.
Offline fuho
  • Country: cz
« Reply #396 on: June 03, 2022, 01:04:18 pm »
and some info that I noted:...
Hello everyone,
I have this version
Update Osciloscópio
Model: HDS272S
SN: 2146xxx
Version: 4.6.2
MAIN V2.1
Thanks a lot for the info and the new FW guys. Added it all to the repo.
Offline skander36
« Reply #397 on: June 03, 2022, 04:50:36 pm »
HDS272 - SN - 2150920
HW -3.0
SW- 5.4.0
Updated to 5.7.1 from Owon support site.
https://www.owon.com.hk/download.asp?category=Digital%20Oscilloscope&series=HDS200%20Series&model=HDS242(S)&SortTag=Latest%20Firmware
After update menu is in chinese.
For English: System->F1-F2
The following users thanked this post: fuho, giovannirat, Markus2801A, NathanFulton, Flopdoodley
Offline miegapele
  • Country: lt
« Reply #398 on: June 03, 2022, 07:41:34 pm »
Anybody knows what software can be used to control this scope via SCPI?
I tried looking for anything, and most of the stuff is for serial interface, but this scope is using raw libusb-win32 driver
Offline miegapele
  • Country: lt
« Reply #399 on: June 04, 2022, 06:10:37 am »
Just received HDS102S, it has firmware V1.5.0 and there is V1.5.1 on owon website. Reuploaded here
The following users thanked this post: fuho, Markus2801A
