Following up on my
previous post about the various issues reported in this thread:
Model: HDS2102S
SW: v1.4.1 (thanks for posting, gtube)
a-c) Presumed fixed. Didn't retest.
d) Fixed. Switching sampling mode does not appear to change frequency reported, at least for the probe cal square wave
e-g) Presumed fixed. Didn't retest.
h) Presumed present. Didn't retest.
i) Fixed. Trigger triangle and threshold line appear in all combinations of channel and trigger coupling (AC/AC, AC/DC, DC/AC, DC/DC)
j) Fixed. Flopdoodley's report of the auto usage vs channel selection is not correct for this version. Much more intuitively, pressing auto with a single channel signal present now results in that channel being both activated and selected
k) Present. Still no buzzer option in the system menu.
l) Fixed. The 2ns/div bug appears to be squashed. Setting horizontal to 2ns/div and viewing a 25MHz sine from the signal generator shows a quarter wave as 5 divisions. 2ns/div * 5div = 10ns. 10ns/quarter wave * 4 = 40ns. 1/40ns = 25MHz.
There are still a few quirks with the AWG menuing. The "fix" for most of them is to go to the sine, bump frequency up to over 5MHz, then cycle through the waveform types, then try setting stuff again. Since the AWG doesn't support over 5MHz on anything but sine, it will force an exact lower frequency when you change waveforms, thus resetting most of the parameters.
