And about displayed frequency:
Connect the probe to signal generator
Set to Peak detect.
Set Signal generator to Square and 1 -> 10 KHz
Check displayed frequency on scope.
Set Signal generator to Square and 70 -> 80 KHz
(Optional: use Auto button, change frequency on signal generator and check the result on scope).
Peak detect in use. Also, notice the arrow that shows trigger level on right.
Sorry my friend, I can't help you. I understand you have certain expectations and that the HDS272 is failing to meet them.
To me, this is not a defect, the peak detect mode is working as it should and the added captured data happens to be tripping up the freq display. The easy answer to getting a stable reading on the freq display is to simply use sample/normal mode. This device meets Owon's published specification and I find it to be quite a handy and unique tool at this price point.
I can tell you that FW Version 5.4.0 the freq display is still behaving in a manner that you would call defective. There may be a newer version available that might address your concerns.
One thing I noticed from other people's attempt to get new firmware, and the responses from Owon, it would
not be a surprise to discover that there MAY be limited
backward-compatibility between firmware versions. After all, they've had
at least three different versions of the PCB in less than a year's time, multiple FW changes, a known display screen change, the addition of post-production parasite components and a less that willing to attitude to dispense firmware updates (or even communicate).
One could only imagine the cost of technician/programmer/language translator time needed to support years of
previous designs across their global product offerings, not to mention component obsolescence. It's much cheaper to ignore the requests unless there's a real problem that could impact current sales. That's how they can sell these units for less (sometimes much less) than $200.
If potential FW compatibility or lack of customer support is an issue, and you have a window of opportunity to return them, you might consider doing so before that window closes. Best of luck!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Regards
