I just bought the 70 MHz version. It has v3.2.0 firmware. I can adjust the pulse width and rise time in the siggen.
Edit: I just played around a bit more. Although at 1 MHz and above, it does show pulse width and rise time, only the rise time is slightly adjustable. You are still just getting a square wave, instead of a pulse. At 999 KHz and below, you can set things to actually get a pulse. I tried it all the way down to 1 Hz. Another firmware update is needed.
The one feature that seems to be missing is sweep. If Owon is listening, please add sweep in the next firmware. Also, make the firmware easy to find and download.
I didn't take mine apart, since others have done so. From the pictures, the latest circuit boards look OK, with minimal bodge fixes.
I played around with the XY mode, using the curve tracer idea presented by W2AEW. Although it works, bouncing back and forth to change frequency and voltage level is a lot of trouble. As for the display, XY mode is one area where an old analog scope is still better.
I've tested and compared the scope to my much more expensive gear, and this unit seems to be quite accurate. For the money, I'm impresed with this scope/DMM/siggen.
Next, I need to try the PC software, to see what it can do. I hope it allows you to create your own arbitrary waveforms.
Edit: The included X10 probe is very cheaply made. I have better spare probes that I will use instead.
