0 Members and 15 Guests are viewing this topic.
Owon has increased the capabilities on the HDS2102S. it is now 500Msa/s per channel. it is also proven with the pics I posted earlier by me.
Quote from: Orange on December 17, 2022, 09:52:53 amOwon has increased the capabilities on the HDS2102S. it is now 500Msa/s per channel. it is also proven with the pics I posted earlier by me. Those pictures relates with HDS2202(S).For some reason the unit might be marked as HDS2102 but in fact is a HDS2202.
I noticed that it now does 500Ms/s in two channel mode, see pics. It makes sense if you put in a 1Gs/s ADC in the thing. Firmware is 2.0.4, Serial nr HDS2102S2218XXX
My HDS2102S also can do 500MSa/s with both channels active. There was a setting I had to change to make that happen though... Unfortunately, I don't remember the setting, and I can't seem to find it now.Mine is also 2.0.4 firmware.
Quote from: Orange on December 16, 2022, 07:52:39 pmI noticed that it now does 500Ms/s in two channel mode, see pics. It makes sense if you put in a 1Gs/s ADC in the thing. Firmware is 2.0.4, Serial nr HDS2102S2218XXXScreenshots strongly suggests that 500MSa/s is true with two channels ON. This proves that 1) @Orange is lucky and 2) new batch of OWON HDS2102(S) have dual channel 500MSa/s (or single channel 1GSa/s) ADC (contrary to current spec sheet). These HDS200 scopes keep changing and getting better
Quote from: NoMoreMagicSmoke on December 17, 2022, 04:12:04 pmMy HDS2102S also can do 500MSa/s with both channels active. There was a setting I had to change to make that happen though... Unfortunately, I don't remember the setting, and I can't seem to find it now.Mine is also 2.0.4 firmware.mine is ver 1.5.0, only upgradable to v1.5.1 from their website... V2.0.4 is not an option...Quote from: electr_peter on December 17, 2022, 02:15:13 pmQuote from: Orange on December 16, 2022, 07:52:39 pmI noticed that it now does 500Ms/s in two channel mode, see pics. It makes sense if you put in a 1Gs/s ADC in the thing. Firmware is 2.0.4, Serial nr HDS2102S2218XXXScreenshots strongly suggests that 500MSa/s is true with two channels ON. This proves that 1) @Orange is lucky and 2) new batch of OWON HDS2102(S) have dual channel 500MSa/s (or single channel 1GSa/s) ADC (contrary to current spec sheet). These HDS200 scopes keep changing and getting better i guess i bought my HDS2102S too early
This is one time that procrastinating looks like it worked out well to me. Of course now that the 2202s is out, I am slightly wishing I had that one simply for the rms measurement...
What is the best probe for the HDS272S?
Quote from: NoMoreMagicSmoke on December 17, 2022, 04:55:54 pmThis is one time that procrastinating looks like it worked out well to me. Of course now that the 2202s is out, I am slightly wishing I had that one simply for the rms measurement...i've been on look out for ScopeMeter for years and i thought its time when i got HDS200 series into my radar... but i guess it will take forever to make a right choice. we cant be too lucky and we cant be too unlucky as well life goes on..
but if there is hope to mod..
Quote from: NoMoreMagicSmoke on December 17, 2022, 04:12:04 pmMy HDS2102S also can do 500MSa/s with both channels active.You shoudn't trust an Owon unit until you test it.PS: start to read this forum thread at page 1.
Can I use a 100 MHz probe with a 70 MHz HDS272S?
Can I use the OWON OC5010 AC/DC current probe together with the HDS272S?
Quote from: juraj.jurej on December 19, 2022, 11:44:48 amCan I use the OWON OC5010 AC/DC current probe together with the HDS272S?yes you can use it.. even if different brand such as Hantek CC-65 AC/DC current probe, which is much cheaper, you can use.
Thank you, I am already. My HDS272S version is V8.0.0
