This man shows a video about a modification of the LCR GM328, several users asked him if he could share that firmware, to which he posted a link, but it is from an older version, a navigator makes the comment that it is not the same one in the video that it shows, to which I proceeded to download and install and I saw that the lady was right. so I told him this
"I just downloaded the one from the link above, or we are doing something wrong or I don't know, the octaclopator option, servo tester, temper ds18b20 and other options from the menu that you show in this video do not appear, I agree with Olga, It is not the same
I just downloaded it from here
https://mega.nz/file/woRVnIwB#RmrIJbdS1G4DSkQk9EZeSsLU3wR04D1fzR8HOH8Ad7g"
This man, displeased with my comment, repeatedly deletes it, because he doesn't say that he doesn't share it and that's it.
in spanish
este señor muestra un video soble una modificacion del LCR GM328, varios usuarios le preguntamos si podia compartir ese firmware, lo que el colgo un link, pero es de una version mas vieja, a todo eso una navegante lo hace el comentario de que no es el mismo del video que muestra, a lo que procedi a descargar e instalar y vi que la señorita tenia razon. entonces yo le comente esto
" Ja acabo de bajar el del enlace que esta mas arriba, o algo hacemos mal o no se, no aparece la opcion de octoaclopador, probador de servo, temper ds18b20 y otros opciones del menu que tu muestras en este video, coincido con Olga, no es el mismo
lo descarge recien de aca
este señor disgutado con mi comentario me lo borra reiteradamente, porque no dice que no lo comparte y listo.
