I'm looking for bench multimeter to be used mainly in low volts motor control circuits (dc servo drives, microcontrollers, etc)
In my country the test equipment is very expensive but I found that the local distributor of owon match the international price +tax and that makes the OWON XDM3041 4 1/2 my current choice.
There is no review, video, tear down or single writen word about this model and I have my doubs about the quality.
Does anybody own an owon bench multimeter? can you share your oppinion?
Main Features
- 4 inch 480 x 320 pixels high resolution LCD
- resolutions up to 4 1/2 digits
- reading rates up to 150 readings/s
- true RMS AC voltage / current measurement
- dual line display supported
- the change trend analysis accessible via special chart mode
- SCPI supported - remote control, and data-sharing
possible via LAN, USB, RS232 port, and WiFi*
* WiFi module is optional
- multi- IO interface: USB Device / Host, RS232, LAN, and ext.
trigger input
http://lilliputweb.net/digital-oscilloscope/digital-multimeter/xdm-series/xdm3041.html
