Hi Forum,
Looking for advice for hardware sources to develop a school outreach project. I've had some involvement in the past for primary and high school outreach for astronomy and physics. Mostly with that we've been conducting classes at school camps held in dark sky locations for optical astronomy. But one thing that is lacking is outreach in radio astronomy and that seems a glaring shortfall for a country involved in the SKA. I'm looking into the viability of building a portable demonstrator that can be used to give kids a taste of radio asstronomy and in particular interferometry. Basically the intention is to build a demonstrator that can be laid out on a sports field and give kids a taste of interferomentry, because real world signals are so low or noisey we'd have a synthetic source with at least a two antenna array that allows kids to move the source and correlate position with phase shifts, etc., etc.. To do this we need reasonably capable equipment, oscilloscopes, signal generators, frequency counters, etc., etc.. There are it seems many such commecial solutions in the test and measurement industry, but they are just too expensive, without a the luxury of a grant. Our whole startup budget wouldn't even pay for one oscilloscope.
I expect the final portable model would work in or below the 400Mhz range to emulate low frequency radio astronomy similar to what the SKA Low or MWA operate.
One thing that is important for outreach is safety, for this reason we are very keen on hardware that can be operated over a network, having a remote display, keyboard, mouse, etc, etc.. if possible something with an available software library that is hackable, so we can apply perhaps build a custom solution and apply constraints to how kids drive the system. Often this sort of remote requirement appears in automated testing solutions, and combined with the 400Mhz capability it seems the dollars skyrocket.
So I'm hoping someone in the industry might be able to point us to towards reasonably priced source of used or obsolete test equipment that we can purchase to repurpose for the project. I suspect as the communications industry moves towards 5G there must be bucket loads of capable test and measurement hardware being made redundant, assuming some is prepared to let it go cheaply enough which is a separate issue!
