There is possibility to:
1) collect raw data from the DSO to PC, probably realtime (or at least almost realtime)
2) do some special post processing in PC based on that raw data
3) display it on PC Monitor in realtime manner too, possibly on graph etc
so here i ask suggestion if there is special or specific function/feature/processing thats usually needed in any EE discipline while doing analysis using this DSO thing, since i'm not specialized or expert in EE. If there is possibility in term of manpower and time for me to develop it, maybe i'll give it a try. Think of the FFT, A + / - x B function thats already available in the Rigol, but whats not? things like that. I hope i can see some replies. Cheers
Current Development:Version 1.2.0
Version 1.1.3Version 1.1.2Version 1.1.1Features:-Just simple control and display of Rigol DSO (whooping fast XY mode display
-Logic Analyzer alike with peculiar features?
-XY (Line?/Dot) Mode, Persistence View, dV/dDiv
-FFT View, CSV and RAW File Output, BMP Capture and Averaging data.
-Phosphor and persistence simulation
-Beep upon trigger
How to Run:1) NI-Visa driver should be installed (visa32.dll)
2) vb6 runtime (which) i think already installed in WinXP or later.
3) just download the zip, extract the exe and run.
if you worry, make sure your antivirus is active.
I'll provide VB6 runtime install file when
i got home necessary/requested.
