What does it mean? Well, when you're on 1ns/div, you get 40000x length worth of data than what is on your screen (10ns to 400us) if you stop it. If you are at 20us/div you get only 2x (200us to 400us).
And from that point on sample rate goes down, and game repeats, changing ratio "screen/stopped capture length" all the time. I guess table could be compiled. It's just I couldn't care less.
I'm not going to base my work based on side-effects of sample engine architecture..
So if you captured something and then thought "gee I wonder what's either side of that, and you knew your scope worked like this, you'd actually rather re-capture instead of just changing the timebase?
That's kinda, well, silly.
If your answer is yes I would, then what happens if your capture was infrequent and wasn't easy to reproduce?
Sorry but I can't see a way to successfully argue this isn't a potentially useful feature.
The thing is that if recording beyond your screen on short timebases was really such a useful feature then the question for me would be why this isn't a standard feature in scopes? It's not difficult to implement after all. Rigol has done it, although I'm sure it probably down to just using a simplistic system of managing memory than to actual intention. But they not even use it for marketing. In fact, I can't remember that any scope manufacturer has ever promoted being able to "zoom out" as one their core features. While even current marketing material still bangs on about being able to "zoom in" on details. And this when all manufacturers are looking for ways to differentiate themselves from the competition. An oversight?
I don't believe so. As I said, I've never came across of any engineer even asking for this feature - aside Nico of course.
It's so interesting it's probably worthy of a video.
II believe it is. Because while I can see where it comes from I still fail to see any advantage to this method, so a video might help.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
But since we are here I can make a list with oscilloscope brands which support recording beyond the screen (or not):
GW Instek: yes
Keysight: older models: yes, newer models: single mode only
Lecroy: no
MicSig: yes
Rigol: yes
Siglent: no
Tektronix: yes
Yokogawa: ?
Why don't you list specific models instead? This would make much more sense than a vague list of manufacturers of which most have had decades of different products which may or may not all behave the same.
Because if it's by manufacturers only then I guess Siglent would need a "yes" because if I remember right the very early models (CL? CML?) could be set to record beyond the screen when set to long memory (which, as with Rigol, very likely down to the primitive memory management and not really intentional).
Same thing goes for Tek, because as far as I am aware (well I'm at home now and can't check) it's only the scope models which have Auto-Magnify which fully support your method, which if I remember right is limited to the MDO Series (although the old DPO2k/3k may also have had it). Outside that, I think that there are also some models which run a full length acquisition only on the last acquisition after pressing STOP or in SINGLE, like the Keysight scopes.
And which Keysight "older models" are supposed to support this outside SINGLE mode/STOP? And what about the different Infiniiums? Or the 54700 Series?
And no mention of R&S? Can't check but I don't think they let you sample beyond the screen on short timebases either. Is it supported by the RTM1000? RTM2000? RTM3000? What about the two generations of RTO? I vaguely remember trying once to capture beyond the screen on the RTM1054 and it failed.
Since there doesn't seem to be many who specifically ask for that feature in a scope it would help if you could list some actual *models* that support it (which I'm sure you know it appears you wouldn't buy a scope which doesn't). Because my gut feeling is (can't say for sure because we don't usually test for that kind of thing, simply because no-one has ever asked for it) you will find that this is not widely supported.
