Author Topic: Volt input jack broke on 121GW  (Read 1977 times)
Offline nemail2Topic starter
  • Country: at
« on: February 04, 2021, 02:58:55 pm »
the input jack on my 121GW broke a while ago and I managed to smelt it together again which lasted for like a year or so but now the part has fallen off again and I just wanted to check whether this has happened to anyone else and whether there could be some replacement part available.
All the input jacks are one solid part, unfortunately. So if I'd find one fitting input jack, I'd had to mod everything a bit in order to remove the broken part of the current input jack assembly...
Any ideas? I wrote to Dave a while ago but he didn't respond, unfortunately (no offense taken)...
Thanks yall!
Boron rhymes with moron
The following users thanked this post: joerg_rw
Re: Volt input jack broke on 121GW
« Reply #1 on: February 04, 2021, 07:36:19 pm »
The following users thanked this post: nemail2, joerg_rw
  • Country: at
« Reply #2 on: February 07, 2021, 12:02:14 am »
Oh another one.  :(
Quote this post for Dave to see:
https://www.eevblog.com/forum/testgear/eevblog-121gw-multimeter-issues/msg2792850/#msg2792850
thanks, I did that but unfortunately Dave didn't respond yet. I really hope that he'll send me a replacement jack. I'd even pay for it...
Offline drussell
  • Hardcore Geek
« Reply #3 on: February 07, 2021, 12:59:48 am »
Did you send an e-mail to his main address, as requested below?
Email me dave AT eevblog DOT com with 121GW Connector in the title and your address and I'll ship you a new one.
Offline J-R
« Reply #4 on: February 07, 2021, 11:37:56 am »
For documentation purposes, were you using UEi or Brymen test leads?
  • Country: at
« Reply #5 on: February 07, 2021, 05:21:06 pm »
No not yet, because my meter isn't within the affected serial numbers an because tautech said I should just quote the post (which I did).
Will send him an e-mail.
I am using the Probemaster 8043SK kit. https://probemaster.com/8000-series-test-lead-master-kits/
Offline joerg_rw
« Reply #6 on: October 31, 2022, 12:22:32 am »
only found this topic today, while searching for 121GW related.
the input jack on my 121GW broke a while ago ...
exactly same here, I don't even need to post a picture, it looks 100% identical.
Using the probes marked "B.T.C" (Brymen? "1kV 10A CAT-II/IV" with screw-on 4mm for the tips, like https://www.welectron.com/Brymen-BL21S2-T4SC-Silicone-Test-Leads ) that shipped with the 121GW  The shard that broke off the jack in DMM got stuck in the plug of probe, no way to get it out
cheers
/jOERG
« Last Edit: October 31, 2022, 01:12:27 am by joerg_rw »
Offline J-R
« Reply #7 on: November 05, 2022, 07:52:08 am »
I like the UEi leads better for the 121GW mechanically.  They glide in and out very well...
It would be nice for those of us with 121GWs that are out of warranty to be able to officially buy a spare set of input jacks, just in case.
Offline e0ne199
  • Country: id
« Reply #8 on: November 05, 2022, 09:54:08 am »
Thanks yall!
is your probe jack a little big it's hard to insert to your 121GW's input jack? or is it because of aging?
