Used a SDS1104X HD as SDS800X HD models are packed for a road trip.
A couple screenshots for your study.
I totally understand your point.
I'm just saying it would be nice in devices with DP/HDMI outputs could adjust to ultra wide screens or two monitors.
If I remember correctly, Keysight can work with 2 screens, so for example you can put statistics on other screen, but there is no way to stretch view of waveform to wide format.
TEK on the other hand might be stretching to wide screen, but i couldn't find way to deattach waveforms to separate window that could be moved to second screen.
And again, I know that is not needed, but see no reason why that should not be possible.
As an example I had captures with decoding of some protocols, and simply there was not enough room for that decoded data, that would be there if i could use wider screen.
