Hi! i thought to ask here about the parts of the probes, i would like to know the "real" name for the detachable hook tip of the probe, and also wondering if they are a standard size for probes of the same bandwidth even if they are from different manufacturers. Ive seen some appear much thicker than others but wonder if that's just an illusion caused by a probe being shorter or longer than other ones. Also, if anyone happens to know where i may find those hook tips online to purchase them without the probe, that would be great. Thank you!
Random image from Google
If you mean the one like above example, yep, they get lost easily, I made my self, use piano/guitar wire, wind it on a stiff steel, such as a nail, but abit smaller in diameter compared to the probe's ground near tip, as it will un-wind a bit by itself, it will be nice fit & snug to the tip, suggesting to do trial and error 1st.
Reheat with hot air if needed during the winding at certain wire.
Actually copper wire works too, but not as robust as the steel wire, once the winding is done, wrapped it with heat shrink tubing to maintain the tight winding.
