Hi everyone,
Today I received instructions with pictures from the seller of the P6500 probes how to optimize them. I think the thought was, if I’m not satisfied, I can still return them after the procedure. Disassembly was quite simple, and I must say mine also looks the same inside as the pictures of Kosmic even if the cable is black and thinner. There are two trimm capacitors and 3 potentiometers. The same construction as within the Tektronix P6139B probe.
After about half an hour playing with the settings the probe performs much better. -3db point is at 100Mhz so still no 500Mhz passive probe but better (-6db is actually near 400Mhz…). My performance is no in the range what Kosmic and jjoonathan measured.
Below the old vs new frequency response vs the P6139B probe:
35ps rise time Square wave 10Mhz signal "P6500 received settings" (Yellow is reference)
35ps rise time Square wave 10Mhz signal "P6500 Optimized settings" (Yellow is reference)
35ps rise time Square wave 10Mhz signal "P6500 Optimized settings zoom" (Yellow is reference)
Optimization setup:
Manufacturer optimisation procedure:
Addjust the trimmers in the order of R1->R3->R2 then repeat to obtain optimal response. It helps also to tweek the hi freqency response if you tweek C4.
To sum things up, clones seem to be the same as others on the forum have, it just seems i got a lot with bad internal adjustment. The probes if adjusted can resolve frequencies over 100Mhz and i can not describe them as terrible anymore. Still the usefulness with their high capacitance is limited. Even with an 50ohm source the probe loading is considerable influence over 100Mhz. So in general i would say a 100Mhz probe with extended response:) Its one thing to measure signal generator outputs or pulse generators and another a real circuit.
But then if i compare this to a low cost TPP0250 (250Mhz) Tektronix probe that can be had for 30-50€ if you are patient on eBay and their 3.9pF capacitance this is no comparison. But its a shame the TPP range can be only used on modern Tektronix scopes and the P6139B is their last higher freqency universal one... I will also do a comparison to German TESTEC HF212 300Mhz probes when i get them. They can be had for 44€ new.
