Author Topic: Oscilloscope frequency response correction program  (Read 4240 times)
Offline dEdt
  • Catch me if you can
Re: Oscilloscope frequency response correction program
« Reply #25 on: September 13, 2020, 06:37:45 pm »
Hello,
there is a Spectrum Analyzer program available for the ADALM Pluto free of charge called SATSAGEN. It has a signal generator as well. The program will perform the frequency and bandwidth extension of the hardware so you can use it from 70 MHz to 6000 MHz. Should be sufficient to challenge the Siglent SDS 2000X Plus  ;)
You can find it here:
http://www.albfer.com/en/2020/02/21/satsagen-2/
Kind Regards
jse
« Last Edit: September 14, 2020, 08:57:11 am by dEdt »
“Have patience. All things are difficult before they become easy.”
Saadi Shirazi (1210-1291)
