Author Topic: Pasternack PE6008-50 thru term  (Read 2697 times)
Online joeqsmithTopic starter
« on: May 24, 2016, 02:24:13 am »
Had a few minutes so took one of these apart today (it had been damaged) and it uses a 1/4 axial part.   I thought for fun I would improve the design by using four 200 ohm resistors to decrease the inductance.   That was a bust.  The capacitance to the case is really bad now.   Think a couple of 100 ohm 1206s may fit from the pin to the case.
Added picture showing what not to do.
« Last Edit: May 24, 2016, 10:45:50 am by joeqsmith »
Re: Pasternack PE6008-50 thru term
« Reply #1 on: May 24, 2016, 04:50:15 pm »
Using four 200 ohm 1206s.
« Reply #2 on: May 25, 2016, 04:54:22 pm »
Two 100 ohm 1206's.
