thanks robrenz,
when I stack 4mm banana plugs, it is the same wall thickness and I had the feeling it is stable enough, that is why I guessed it should work.
My other option with the 4mm thread idea, will than have the same problem and even envolves my imprecise handwork. So this should be even worse.
What would you do to solve this?
