Author Topic: Oscilliscope to use with unreliable power source (mobile lab)  (Read 940 times)
Offline Cowboyengine3rTopic starter
« on: February 08, 2021, 04:08:06 am »
First post, hope it's in the right area. I am downsizing and hitting the road but want to continue on with my hobby. Being in a travel trailer sometimes I'll have mains or "shore" power, other times it'll be a generator, a regular dirty one, or battery/inverter power. I have a pure sine inverter to run my bench Siglent SDS1202X-E but I'm curious if there is a decent PC based one like the Owon VDS1022I (dave mentioned it in the $350 lab and all the reviews on here it seems to be the better one)? Maybe a handheld one as space is at a premium and being able run one on battery power (12v) would be great, trying to fit my lab in small pelican type case. I'm  a newbie so beyond basic things I don't have much in the way of specific needs to look for.
For the rest of the lab I'm planning to use a 12v to 24v step up converter to run a 30V/3A PSU and a 24V/3A soldering iron, battery operated LCR, and I'm looking into a waveform generator kit.
Offline bob91343
Re: Oscilliscope to use with unreliable power source (mobile lab)
« Reply #1 on: February 08, 2021, 05:04:05 am »
I think your best bet is to use a gasoline generator for 120V and be done with it.  Otherwise there is so much to remember and mistakes ready to be made.  I assume efficiency is not of primary concern.
I recently purchased a USB powered soldering iron.  It's only good for small jobs but is very portable and does well within its limits.
« Reply #2 on: February 08, 2021, 05:07:35 am »
Its not a pure sine wave generator, would a modified wave cause noise or other problems? Sorry no info to be found on that part from what I've searched
Offline 2N3055
  • Country: hr
« Reply #4 on: February 08, 2021, 07:57:15 am »
If you can afford it Micsig tablet scope is highly recommended... It runs completely on battery for 4-5 hours...
Or some of the handhelds, but those are going to be more expensive..
The following users thanked this post: Fungus
Offline Fungus
« Reply #5 on: February 08, 2021, 08:43:12 am »
The switching power supplies in many oscilloscopes will run on DC power:
https://www.eevblog.com/forum/testgear/battery-pack-for-rigol-ds1054z/
My Micsig power supply says "Output 12V 3A" on it so you can run/charge the 'scope from a 12V DC supply.
Very noisy/smelly, probably high EMI emissions.
« Last Edit: February 08, 2021, 07:32:49 pm by Fungus »
« Reply #6 on: February 08, 2021, 05:55:43 pm »
I wish I had enough budget for the Micsig, but  whatever I buy needs to be an even trade once I sell my Siglent. I thought about getting a Siglent SHS806 as its very similar to my benchtop model but $500 is too much
« Last Edit: February 08, 2021, 06:11:59 pm by Cowboyengine3r »
« Reply #7 on: February 08, 2021, 06:25:02 pm »
What kind of bandwidth do you need?
If it's not too high, a used Philips/Fluke Scopemeter might be a viable option.
Offline tautech
« Reply #8 on: February 08, 2021, 06:53:22 pm »
All day long a SDS1202X-E is a totally better scope than a SHS800.
I don't imagine you will have any issues supplying the X-E with dirty power other than the local EMI from that supply.
These sensitive scopes can pick up all manner of muck if it's out there.
