Hi Everyone,
I apologize if someone already asked this but I have been looking in this forum and I didn't find any information about the following issue.
I recently bought a SDS 1104X-E oscilloscope; I am now writing some scripts to control it using my Ubuntu laptop. When I run the line echo "C4: TRACE ON"> /dev/usbtmc0 (where "C" is the channel) the oscilloscope just ignores it. If I run the same line but for C1,C2 or C3 everything works. I turned C4 manually and then set up the voltage per division using the script and it worked. Can someone point me to the right place to start debugging this issue? any help will be highly appreciated
regards,
-Bitt
