Author Topic: Ordering some gear, yay or nay  (Read 3495 times)
Offline Reef_StevensTopic starter
« on: November 26, 2015, 11:34:33 pm »
Going to order my first lot of testing gear. Does this stuff seem alright? Open to any suggestions, trying to stick to the approximate price of the listed components.
DSO: Tektronix TSB1052B
http://au.element14.com/tektronix/tbs1052b/oscilloscope-2ch-50mhz-1gsps/dp/238321601
PSU: TENMA 72-2540
http://au.element14.com/tenma/72-2540/power-supply-1ch-30v-5a-prog/dp/244541201
Cheers, Reef.
Offline Howardlong
Re: Ordering some gear, yay or nay
« Reply #1 on: November 26, 2015, 11:51:39 pm »
Value for money, the Rigol DS1054Z is a far better investment as a scope in my opinion.
The Tek is only 2 channels and has a miniscule 2.5k points for starters.
Edit: typo.
« Last Edit: November 26, 2015, 11:56:04 pm by Howardlong »
Offline rdl
« Reply #2 on: November 26, 2015, 11:53:00 pm »
Almost everyone here is going to tell you to buy a Rigol DS1054z.
That power supply is a re-badged Korad. You might be able to find the original Korad version at a lower price.
Offline ataradov
    • Personal site
« Reply #3 on: November 26, 2015, 11:53:28 pm »
Are you buying Tektroinx just for the name? In all other respects it is way worse that the Rigol DS1054Z.
Alex
Offline nctnico
« Reply #4 on: November 27, 2015, 12:30:48 am »
I agree. Buy a DS1000Z, shell out a couple of thousand $ or buy something second hand.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #5 on: November 27, 2015, 12:59:12 am »
The price down here is almost the same between the Tektronix and the Rigol, the Rigol is currently the forums most recommended DSO for good reason, very hard to beat and available from Emona Instruments linked below.
And if you are buying from Element 14 don't forget that you may be eligible for a bonus pictured below, they have indicated to us recently that a review of their pricing structure is being undertaken and are very keen to talk turkey on particular products.
http://www.emona.com.au/products/electronic-test-measure/oscilloscopes/ds1054z.html#.Vlen0dIrIdU
« Last Edit: November 27, 2015, 07:55:44 am by Muttley Snickers »
Offline Fungus
« Reply #6 on: November 27, 2015, 07:32:32 am »
2.5k points is a deal-breaker IMHO. Simply not enough in 2015, eg. a DS1054Z has 5,000 times more memory than that (even without hacking - you can get even more by hacking!)
Being able to record signals and zoom in is a fundamental feature of DSOs.
« Last Edit: November 27, 2015, 01:12:40 pm by Fungus »
Offline tautech
« Reply #7 on: November 27, 2015, 01:05:47 pm »
If you have that sort of budget for a DSO and only want/need 2 channels this may interest you:
http://www.triotest.com.au/shop/siglent/3816-siglent-sds1102x-digital-oscilloscope-100mhz-1gsas-2-channel.html
Apart from better basic specs it also has 400V rated channel inputs that offer better safety if you are doing any mains or SMPS primary side work.
