perhaps Dave has covered this in the EEVblog #46?
No, he does not. The best Video I have found so far is this:
[youtube]
[/youtube]
Which basically should have you set anyway, but I've tried and my plastic made frightening crackling noises, so I wondered, wether there is a more elegant version.
Now you've piqued our interest: why do you need to open the meter in the first place?
You'd be disappointed. I am heavily challenged to actually use a multimeter, I'd never even think of repairing one. Just some visual inspection I intend.
I use a guitar pick that the local shop gave me
That is an excellent idea as well, as a former bass player I should have some flying around. Somewhere, that is.
My device, when bought used, had a sticker across the lower and upper half gap (no photo made unfortunately) that advised against levering (with a screwdriver). Hence this thread. I was wondering, wether the two front holes in the batterie compartment might have anything to do with it.
But the punchline I'll take away, you have to lever out the front part some way, there is no trick in releasing the snap mechanism in a friedly way.
Thanks again to all of you!
